Question about Home
Shower leak i have redone our shower grout but after a while it is leaking again is there some clear that we can just paint on it for example to totaly seal it as we are so fed up p.thankyouarticularly as our shower is upstairs
    Problem Solver:
  • 19 Answers
This may not be a grout problem . I want you to run the shower and check the shower arm behind the wall plate and the toe tester(spout ) for water leaking behind the wall.If you dont find a leak than their could be a problem with the rubber membrane under your tiles.
Posted on Feb 02, 2009
How do i seal a crack in the grout on the shower floor using wet area silicone? Is this suitable and what do we do?
problem usually happens when grout is not fully cured and sealed when water penetrates it so... remove old grout using grout removal tool (you can pick up from any where that sells flooring(tile) pick up some new sanded grout to match and sealer apply then seal 24 hrs cure time is req. before sealer wait 2 hrs then re-apply sealer 7_2_2014_6_45_58_am.jpg
Aug 31, 2013 | Home
I had a shower total replacement less than two years ago. Company out of business now. Shower grout has cracked bad at base and in corner all the way down. I need to re-grout. Problem is the gap in corner...
Use a good quality bath and tub caulk applied to the deeper parts of the gap. Do not fill all the way out to the top of the gap with the caulk. When the caulk is dry, then apply the same color grout over the caulk.
Jan 21, 2013 | Home
I bought a maax shower base. i am going to intall a cement board on the wall, water proof it and then tile over it. The shower base has a flange that is 1/4'' thick. do i install the cement board on top of...
There are two ways that I would do it depending on the width of the ledge on top of shower base. If you have enouch room I would shim studs with strips of material thick enough to bring the surface out even with flange on shower base. Then I would put cement board(wonder board) on wall and over shower flange to set on top of shower base. Finish seams on wall board per manufacturers directions,Let seam filler dry then seal with thompsons water seal or equivalent sealer. Let that dry then tile on that grouting and sealing with quality caulk at joint between shower base and tile.
If ledge on shower base is not wide enough then I would place cement board directly to studs then use filler strips on face of shower base flange to bring two surfaces flush. Water seal let dry and tile again coming down over top of shower. Grout and caulk to finish. P.S. I would use a siliconized latex emulsifier to mix in with grout. It gives a better ware proof seal. Hope this helps you. Good luck and thank you.
Jan 30, 2011 | Maax Acrylic Base for Shower - 102623
I'm insytalling new tile in shower should the frame of the shower doors be caulked?
Hello. Definitely yes. You want the tile, grout and caulk to be a semipermanent barrier for the water. If you do not caulk the frame, water will get in there and either leak or cause mold to form. Use a good quality silicon caulk, either clear, or white or a color that matches your grout lines. J.
Jul 28, 2010 | Home
Shower stall in master bath of a 15 yr old home. the shower started having water problems after about 1 year, leaking water onto the drywall next to the stall. we have tried everything-recalking, sealing...
Did you use plastic pipe? What about the shower head? Does it have a rubber o-ring in it? Pull the pipe out of the wall at the shower head and peek inside for the o-ring. If it is there, just snug up the pipe, do not over tighten. We were ready with crow bars in hand to destroy a brand new shower we just finished, because we thought we had w broken pipe, Then the owner says he torqued up the shower head as tight as he could and I read where it had to be just finger tight. One more place to check is the faucet itself, take off the trim ring and look in there for drips. It could be filling up the wall cavity and stay wet for days. I would take apart the drywall on the other side before busting up the tile again. Check it out.
Apr 24, 2010 | Kohler Home
I have frameless shower doors, the bottom sill is tile, with grout lines. Water leaks under the shower door through the grout lines, how to correct this.
if the glass actually contacts the tile you can go to the homedepot or similar place and buy some glass silicone sealer and just run a nice bead of caulk along the line, make sure you get clear silicone and let it thooroughly dry before you get it wet
Sep 14, 2009 | Dmm Vigo Frameless Shower Enclosure with...
Leak in the shower is leaking water through the ceiling
SInce it is wet both under and behind the shower I would rule out the drain floor pan and drain system and think it most likely to be the pipe leaking from the mixing faucets to the shower head. Find studs directly behind shower faucet, n each side. Locate the center of the studs and put vertical lines up and down on the center line of the two studs closes to but outside the shower  faucet on each side. Approximate 6 inches or so  up and down for the height of the shower faucet (Valve, not head) Put Horizontal lines across between the two line at both the top and the bottom/ You now have a square.Using a Razor knife(Sometimes called a box knife, stanley 99a for example) cut into the lines of the square back and forth as deep as you can. Cut an x  acrossthe square corner to corner again as deep as you can . Lightly hit the center of the x until the drywall caves in . Cut the remaining drywall out for the square. Now while  the shower is running you will be able to see whee the leak is. Use pipe seal after disassembling the loose fiting or repair the leak iun what ever manner is necessary. Replace and repair the hole made in the drywall  with another piece of drywall, tape and joint cement. .
Feb 27, 2009 | Home
Water leak outside valve
You have a leak where the back plate goes up to the wall OR there is a gasket missing from the trim installation. If this is a tile shower i would suspect the first and use clear tub/tile chaulking to seal around the edge of the plate paying close attention to the grout lines.
Dec 09, 2008 | Rohl A2400 Country Bath TRIM ONLY PRESSURE...
Hi lorenzotwalk,
I'm Harvey the Master Plumber.
Your problem is: When you use the shower, water leaks through the ceiling.
First, since it only leaks when you're using it you can ignore the water lines. Now comes the detective work. Look very closely at any place the water can squeeze thru, i.e. cracks in grout or caulk, etc. Don't forget to look on the floor imediately outside the shower and around the shower door if any. If found it must be scraped out, cleaned and dryed to get good adhesion, then caulked with a high quality silicone caulk (color of your choise). Any other caulk will crack no mater what they say.
Let dry for 24 hrs.
If you havent found this kind of problem it's time to look at the drain line connection. You may have to open the ceiling to do this, that's why I'm always carefull in the first step. Turn the water on and watch the drain connection. If it leaks there, it must be repaired. In this case you might cunsider checking the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 18, 2008 | Home
Home Logo
288 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
