You can purchase several different attachments/brushes specifically designed for
hard-to-get-at coils, as well as a soft brush, at
your favorite store.
How to clean the coils
SOURCE: Access to clean coils on kscs25inss00
You need to get a bottle brush they are about 18" long maybe longer and made for getting into these area's to clean the coils. My frig is set up the same way and hate it. Cause when they are that dirty cause's so many things to happen all bad. I have used my air compressor to blow them clean and then chase little dust bunnies around the kitchen. I have been thinking about this same problem for awhile now and bottle brush is the best option for now that I have heard of. ken
SOURCE: frost build up on the back wall of the freezer
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
SOURCE: refrigerator not cooling
Check in the freezer section by removing the food exposing the rear inside panel. DO you see frost beginning to build upon the rear inside panel of your freezer section? If so, the is a simple defrost problem and can be repaired easily. For testing purpose, st both control to the middle setting and do not move them during the entire testing period. Moving the controls only makes things worse.... Let me know what you find....
Waiting to hear from you,
Eric Campion
SOURCE: Kenmore Elite Side by Side refrigerator not cooling enough
it could be either gas problem or may be compressor is not working
Hi: I've dealt with Kenmore for 30 years. Unfortunately the new model numbers don't reveal the age. I must assume it's a newer model. I'm not disputing what you said about it running all the time, but please read on. Oddly enough the new energy efficient referigators run 70 to 80% of the time. They use a smaller compressor without the big amperage start-up. The best I can describe them is that they freewheel alot. The 106......of your model number means it was built by Whirlpool. A very quite and energy efficent refrigerator. If your power bill is high get a meter from your power company, most have them. Just to double check the power consumption. Good luck Jeff
