I have a troy 512 plus micr printer that I am trying to network with a desktop and laptop that both use Windows Vista. I got the troy printer used and did not receive the CD or instruction manual. I can not get mt desktop to recognize the troy. Also, how do tell if there's toner in the printer?
  • 4 Answers
My name is Brian McMillen and I am a Technical Support Representative with TROY Group, Inc. You will find the drivers and support files for our products at our website: http://www.troygroup.com/support/discontinued.aspx. Currently, however, the TROY fonts will not work with Vista. We have spoken with Microsoft in regards to this issue and Microsoft should have this resolved with the Service Pack 2 update for Vista/Server 2008. If you need further support, please feel free to contact me by calling 800-633-2266 x 218 or via email to bmcmillen@troygroup.com.
Regards,
Brian
Posted on Mar 23, 2009
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
The information printed on My troy micr 2420 laser is not properlly aligned on draft paper. how do correct this? Pls help urgently as the client is waiting.
Hi there!
If not aligned, just turn is off the printer and turn it on. It will self align the cartridge.
If not, turn it off the printer again and unplug the power cord. Use your finger to move the ink catridge from left side and after move it to right side of the printer.
Plug the power cable and turn it on again. Just print again. I will be working by now.
I hope it helps you.
Jan 21, 2011 | Troy MICR 2420 Laser Printer
Can't get epson Stylus nx400 to print from wireless laptops. printer connected to desktop with windows xp pro. both laptops use windows vista home premium.
As your printer is not wireless itself you need to shared the printer. To enable this goto Control Panel on your desktop, select printers, right click your printer and there should be an option for sharing. Enable sharing.
Now using your Vista laptops you should connect to your home network (in your case this is probably a wireless router, as long as your desktop is connected to this router too), goto Control Panel, printers, add printer, search for printer not connected to this copmputer (or network printer).
Hopefully the Vista laptops will then pick it up and install it correctly. You may be asked to install the correct driver for the vista machines. Windows should provide you with instructions on how to do this.
Hope this helps, www.PuterCare.com
Feb 20, 2010 | Epson Stylus NX400 InkJet Printer
1332 infoprint printer not supporting 1332 toner cartridge
If the toner in the machine is NOT MIRC it will not work in a MIRC printer. Get the correct toner cartridge or get a NON MICR printer to put your toner in. MICR uses a special toner (magnetic) for printing checks and the printer is usually modified at the factory (troy or others) to make it print using MICR toner. No way around it.
Aug 14, 2009 | IBM Infoprint 1332 Laser Printer
I want a printer driver for my Troy Micr 8150 secure Ex
go to www.driverguide.com
you should be able to get your drivers from there and its free to join.
Apr 30, 2009 | Troy MICR 8150 Secure Ex Laser Printer
I WANT A PRINTER DRIVER FOR MY TROY MICR 8150 SECURE EX
sir i want to download hp lazerzet 1018 plzzzz help me
Can I use my Kodak 5300, installed as my network printer on a desktop running Windows XP with my new laptop running Vista? If so, do I run the install disk (with Vista drivers) on the laptop or what?
you should be able to as long as there are Vista drivers available.
make sure you first share your printer from the desktop it is attached to. then on the Visa laptop try to Add Printer choosing network printer (as opposed to local printer) and browse for the shared printer. Vista should tell you it has to install software so allow it to. Have the disk ready (does it have Vista drivers on it do you know?).
Word of caution: Vista's a little quirky with networked printers so you may have to delete the printer on the laptop and add it back if it doesn't work the first time (I had to do that even though all machines involved were Vista :/ ).
Cheers.
Mar 31, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
ERROR MESSAGE READS "LOAD FILE AND EXECUTE" HELP?
It is possible that the printer is somehow waiting for a firmware upgrade file. If you power off the printer and remove the TROY Font DIMM, then power on, does the issue message still appear? If it does not then the problem could be the TROY Font DIMM. If it does then I would look at the Formatter. If you need any further assistance, please feel free to contact me by calling 800-633-2266 x 218 or via email to bmcmillen@troygroup.com.
Regards,
Brian
Feb 10, 2009 | Troy MICR 4200 Secure Laser Printer
Hp Vista Laptop won't communicate with XP desktop when trying Prt
u have share your printer and add your printer in laptop u have to connect both pc in lan (local area connection ) or u can use the cross cable of lan when both pc connected then u have share your printer in xp then u have to add the printer in your vista laptop by using printer add visrd there is option on it u have to select the network printer & add it in to vista then u can print it
or
there is onther way u can install your printer in a laptop u need ur printer vista download
Jan 17, 2009 | Office Equipment & Supplies
200 people viewed this question
k24674
jasbo
jasbo
