Question about Insignia 37" LCD Flat-Panel HDTV
TV was playing, then the screen turned black.
For 4 weeks, my Insignia TV was playing great. Then the screen turned black. When I tried to turn it back on again, the blue light came on, but the screen is, still, black. When I pressed the remote again, the red light flashed 5 times but no screen
  • 2 more comments
  • Worstbuyguy Feb 22, 2009
    I have a 37-inch Insignia 1080p flat panel that I bought 12 weeks ago. The screen will go black but the sound will continue. After I turn the TV off and back on, everything is fine.
  • Worstbuyguy Feb 28, 2009
    I tried the flashlight procedure but there was no image around the edge.
  • Nicci69 Mar 17, 2009
    I went to turn my television on and the blue light comes on for a second and the TV tries to come but it goes back to the black screen and the red light is on.
  • randy6609 Mar 18, 2009
    i was watching the t.v then it just went black no sound to. but the power light showiing it on.
  • 718 Answers
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Posted on Feb 24, 2009
  • Josh Teslow Mar 06, 2013
    marionbagget, I have the exact problem you are describing. Black screen but I can tell that the image is still being displayed with a flashlight. I checked the test points on my inverter board with a multimeter. All seemed to be consistent. i.e. the board is probably fine? What you you think? Or could it be the panel?
I have a insignia ns-lcd37-09 tv.The screen suddenly turned green.I can here sound but no picture.can you help?
Change input device to some other which you know works for sure. If problem persists, try changing the channel. If you notice same problem, this may need attention by a qualified service technician.
Jul 21, 2012 | Insignia NS-LCD37 37 in. LCD TV
Ihave a insignia ns-lcd47hd-09 tv. when i press the power button the light turns blue but no picture comes on only black screen.
I think your insignia is set for SHOP mode instead of HOME mode. I changed mine to HOME and it's working fine now. Press your menu button and then scroll down to setup. You're looking for Plug and PLay which should be the very first choice. If it's greyed out as mine was you'll have to change your imput from HDMI to TV in order to get to the P&P. Once you're in the Plug and Play your first choice is language. The second should be SHOP or HOME. Make sure to select HOME. You can skip scanning for channels. This fixed my problem with the blue light. The store uses SHOP so if someone plays around and changes something, all they have to do is shut off the TV and turn it back on. Please let me know if this works.
Oct 03, 2011 | Insignia NS-LCD47HD-09 47 in. LCD TV
My screen went black, its a insignia 20'' lcd.
Generally, problems like this require repairs to resolve. You may carry the TV in to the place of purchase to pursue service options.
Mar 09, 2010 | Insignia LCDTV26 26 in. Television
I have a 42 in Insignia LCD that I have only had
If a problem like this should develop within the retailer's return period, it is recommended that the TV be returned for an exchange.
Jan 19, 2010 | Insignia LCDTV26 26 in. Television
I have almost the same problemwhen my tv is on it starts off by goin up and down and just jumpin I've had it 4-5 years now and just the beginnin of this year it starts jumpin. its not like back in the day when the old tv starts jumpin all u have 2 do is go 2 the back of the tv and play with a button that will stop it from jumpin now 4 this tv i have 2 call a mechanic to fix it so please can u help me
Thank u. Ms. English.
Jun 03, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia ns-lcd42hd screen flutters
This television is having trouble with sync circuits. It probably has some component adding erratic noise voltage to the circuit causing the instability in the sync lock circuits. The solution is to locate the bad component with an oscilloscope by following the signal path with oscilloscope probe until you find the irregular signal and then replace the part. This part could be either capacitors or ringing resistors.It may also be a component in you solid state signal processor. You should have it tested in a service center and see if they can locate the bad components. Then see if it worth replacing with the cost of parts and labor. Hope this helps you with your problem.
May 12, 2009 | Insignia 37" LCD Flat-Panel HDTV
My 26 inch insignia has sound but black picture
Hi freelingtrapt,
I am happy to help, we need to check the backlight inverter.
  1. Turn tv on and get to a point that you have audio.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely at the screen for a very dark video image.
If you see an image you have a bad inverter, you should be able to replace it yourself. I can walk you through in chat. Let me know your findings. Lone99star
Jan 22, 2009 | Insignia LCDTV26 26 in. Television
Insignia NS-DXA1 APT remote control doesn't work
Set your TV input to match the input your have your Insigna connected to. Then run the Insignia setup. You are getting a distorted screen because you probably have the Insignia connected to channel 3 and the TV on channel 4.
Dec 30, 2008 | Insignia Digital-to-Analog Converter for...
Insignia 37" LCD Flat-Panel HDTV Logo
2,967 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
