Question about JVC DR-MV100B DVD Recorder/VCR
Need codes I have a RCA D771 universal remote and I need the codes to access a JVC DR-MV100B DVD Recorder / VCR Combo
  • 1,214 Answers
Unit does not have a manual, but I did find this -
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Let me know if this works, and if not, I'll keep looking.
Posted on Feb 01, 2009
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ... > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
Jvc-drr-mv100b stuck at hello message. dvd door also not opening. have turned it off and unplugged without benefit
Possibly Cap C127 on PSU is bad. This is my problem. See
Apr 17, 2011 | JVC DR-MV100B DVD Recorder/VCR
I lost my JVC remote control model DR-MV79B, This is a some kind of combo DVD/VCR. I tried a rca universal but didi'work
Each universal remote have certain code for each TV, read the manual for code, match the code with your JVC.
Feb 10, 2011 | JVC DR-MV79B DVD Recorder/VCR
Why my dr-mv100b dvd door stays open?
Try to look inside from the tray, is the small belt in place or does the gear spin freely and the tray does not move? Or is the issue with just the door not closing the tray is inside?
Sep 05, 2009 | JVC DR-MV100B DVD Recorder/VCR
The system or DVD recorder turns off itself
It could be because your unit is overheating. Shutting itself off is your player's way of protecting itself. Causes can be form anything to direct exposure to sunlight, Something heavy is on top of the player, to disk speed being to fast.
Mar 31, 2009 | GoVideo Go Video DVD/VCR Combo
I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Feb 03, 2009 | JVC DR-MV1S DVD Recorder/VCR
Jvc dr-mv100b
this is due to the settings of your player.
you should have settings for SP ( Standard Play ) LP ( Long Play ) et,c.
the quality may differ slightly, but you need to refer to your user manual for how to adjust the recording times. also if your dvd supports DL ( dual layer disks ) this will obviously double the recording times.
Mike @ Compurepair.
Jan 28, 2009 | JVC DR-MV100B DVD Recorder/VCR
RCA RCR 451 universal remote codes click the find codes link.. then select your clicker's model number from the drop down box.
The problem is that it does not list the steps to program the remote after you have the correct code. Does anybody have this information?
Sep 03, 2008 | RCA Universal Remote Control
JVC DR-MV100B DVD Recorder/VCR Logo
451 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
