Question about Magnum DeltaForce CB Radio
I am trying to wire a d104 mic to a midlan 76-863 base can someone give me the wireing diagram
    Problem Solver:
  • 16 Answers
Pin 1 is white
Pin 2 is shield and blue together
Pin 3 isBlack
Pin 4 is Red
Yellow no connection. Hope this helps........
Posted on May 27, 2009
How to wire a D104 mike to a DAK IX Base Radio
Is the d104 a amplified tug8 (4 wire) or tug9 (6 wire)
or is it a non amplified mic?
Found this...hope it helps..........
Astatic (4 wire)
1- White
2- Shield
3- Black
4- Red
Astatic (6 wire)
1- White
2- Shield
3- Blue
4- Red
Black- N/C
Yellow- N/C
Dec 15, 2017 | Radio Communications
When i keyup my d104 mic on cober 148 gtl ihear feedback squeal.but the d104 work good cobera 2000 gtl
try to keep the mic away from the radio speaker.check to see if its turned up to high.check your mic gain to make sure its like 1/2 open.If these fail then you could solder two 0.001 ceramic disc capacitors from the audio to the shield wires about 3" apart.then on the audio wire in between the 2 caps solder a 4700 ohm 1/4 w resistor.this should work.
Nov 09, 2013 | Midland 1001Z 40-Channels Base CB Radio
D-104 wiring to a cobra cb
Find your radio on this page and then look at the wiring diagrams
Oct 11, 2012 | Astatic D104 T - Ug8 Crystal Microphone...
Rci-2950dx 4 pin microphone wiring schematics
you can't because of the up/down buttons on the mic. the 2950 is a 6 pin and the d-104 is a 4 pin. If you can figure a way to eliminate the u/d switch then go for it. there is a wiring diagram on www.cbtricks.com
Jan 15, 2012 | Midland 1001Z 40-Channels Base CB Radio
I have a uniden Grant like to wire up a 4 wire D104 the mic has white black red shield
Wiring 1 4 pin D104 mic to a Uniden Grant CB is as follows -
  • Pin 1 - Shield - Shield
  • Pin 2 - Audio - White
  • Pin 3 - Transmit - Red
  • Pin 4 - Receive - Black
Regards, Tony
May 05, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
Im trying to wire a astatic d104 m6b to a galaxy 949 mobile can you give a color code for what color wire goes were?i have black white red blue and a bare wire thank you.
This works for any mic.
dont worry about color codes. look at the switches.. there will be a common on both poles of the d104.. those need to be tied together to grnd. pin 1 on mic . the others d104 on n/c side is your rx. pin 4... the n/o one will be your tx pin 3 the other n/o will be audio and will have a wire from the mic element also on that pole of the switch. pin 2..
Sep 25, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
I have an astatic 4 pin d104m6b amplified
Hello there
Nice mic i have 3 of these
here is infornation that you can use to get the diagram i like the first link a lot better though it is in full color Ok just look belowtis post and it will be there ok? I hope that this is very helpful for you
Best regards Michael
Repairing the D
These Astatic D-104 microphones are all vintage. ... Doing so will reveal the
simple wiring and the wiring diagram, pasted to the plate on the inside. ... http://www.k3hkr.com/D104_repair.html - 4k - Similar pages I am needing the wiring description for the astatic d104 - FixYa Oct 24, 2009 ... HELLO THERE The silver eagle d104 is wired just the same as the knight ...
astatic echomax 2000 unilli eagle wiring · wiring diagrams for ... http://www.fixya.com/support/t3271236-am_needing_wiring_desc... - 125k - Similar pages
Nov 17, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Wiring a mic
Pin 1 is white
Shield and blue is to Shell. Guess it means ground
Pin 2 is Red
Yellow and Black no connections. Hope this helps................
Mar 25, 2009 | Magnum DeltaForce CB Radio
Mic wiring
Hello, In case you haven't found it yet, here is for a 2510/ which is a cousin of a radio.
1 - Modulation/ Audio/ White
2 - Ground/ Shield
3 - Transmit/ Red
4 - up button/ NC
5 - down button/ NC
Thats if the D104 is a 4 wire, Mechanic
Aug 30, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Radio Communications Logo
100 people viewed this question
Top Magnum Radio Communications Experts
John Porter
Jim Goldsmith
Jim Goldsmith
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
