Question about Fuji FinePix V10 Digital Camera
Fuji finepix v10 digital camera No.63A01601
This camera fell down and wont turn on when i tried to put it on,but it indicates charging whenever i put it on charge.Apart from the NP40 750mAH battery,i saw another battery inside the camera, round in shape,just like wrist watch battery,i measured it but it reads(0.342VDC,i dont really know the value of that battery,cos no value was written on the battery.I fix another battery reading 1.5VDC,all to no avail. Please i need you to tell me the specification of that battery if u know and tell me what to do next. I am a technical man on electrical/electronics.
    Genius:
  • 2,985 Answers
Check Fuji Customer support re this. It may be a custom device that looks like a battery.
Posted on Aug 01, 2007
I cant get my camera to turn on. Have charged and swapped out 4 different batteries and still wont turn on.
When you put your battery on the charger the light should come on to indicate charging, then go off when the battery is charged. Have you seen that?
Nov 04, 2014 | Panasonic Lumix DMC-FZ5 Digital Camera
It seems to me the most obvious thing to look at would be the power switch. I don't think impact would damage the battery unless it cracked or punctured it - and I assume it hasn't since you haven't mentioned that.
Have you checked the switch itself for any damage, and made sure it's making contact when it's switched, and traced the leads from the switch back to the board - or even all the way to the battery? I think you'll find your problem somewhere in there.
The smaller battery should be for storing long term memory - i.e. any configurable settings. Even if that was dead, the camera would still turn on, it just wouldn't remember any settings.
-Dyllan
Dec 19, 2007 | Fuji FinePix V10 Digital Camera
Camera wont turn on after charging the battery
Bruce, you didn't provide a lot of information but I can tell you that the few times this has ever happened on my Nikon D-90, the battery did not charge, would not charge and I had to throw it away, or it was a charger problem.
I've had it happen when I tried to charge it on my corded Nikon Charger and I never got a charging complete indication after charging over night. When I put it in the camera, the camera indicated it was not charged even though the charger indicated it was charging. But, when I put it on a travel charger, it charged in about an hour and worked fine. The next time I put it on the Nikon charger, it worked fine.
I suggest you verify that the battery is good and charged or capable of charging. If it is, then check to make sure the battery contacts are clean both on the battery and in the camera.
If the contacts are clean and you're sure the battery is good and charged, I'd say the next step is to contact Canon. I've heard their customer service is very good.
May 20, 2014 | Panasonic Lumix DMC-FZ7 Digital Camera
It will charge but after i take it off it wont turn on at all
That means the battery of your camera can't hold a charge. The light on your camera or battery indicating that it's charging flashes whenever it detects any power being wired into the device, not necessarily that the battery is holding power. Depending on what camera model and brand you have, you should contact their customer support for a new battery.
Cheers.
Apr 02, 2011 | Cameras
My camera, a nikon d70s, wont turn on and work. ive taken the battery out and out it back in, still wont work. i then tried 2 charge the battery but still wont work. i then tried to re-set it but it still...
If the camera does respond when you hold down the shutter release, then the internal clock battery may have drained. As the manual says on page 17, charge your main battery, put it in the camera, and leave it be for up to three days.
Feb 15, 2011 | Nikon D70s Digital Camera
My camera fell down in the water. I didn't put it on until such time that arrived home. My husband opened it and removed the sand from the sides of the camera. It was just basically cleaned. However,...
try to buy similar battery then recharge it. but has you know its circuit board need to be cleaned especially if it is fell in salt water, it will cause problem sooner its components will get rusted hence it will gonna operate with a malfunction.
Jan 29, 2011 | Olympus T100 Digital Camera
Camera will Not turning on even when battry is fully charged.
take out your battery and then put it back in mine does that and found out the little black rubber pice fell off
Feb 12, 2009 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Camera wont turn on.
Main power led to on/off switch is crushed and not enough power gets through.
you have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
See the big red wire leading to main on off switch if it crushed thats the problem.
I replaced it with a longer piece of wire.
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Oct 31, 2007 | HP Photosmart M425 Digital Camera
Problem with battery,
Sounds like your battery isn't taking a charge so I would say your battery is the problem
Jun 19, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Fuji FinePix V10 Digital Camera Logo
70 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
