Question about Remington Electric Chain Saw
Chain drive sprocket
Need drive sprocket for remington 3.0 HP 16'' type el8 model 107624-02 thanks , Pete
  • Anonymous Feb 10, 2009
    The saw itself is pretty good, but some dummie went and used plastic gears for the chain adjuster. I returned the 1st saw after 2 wks, and didn't use it much but the gears stripped and the whimpy little metal bracket that fits in the blade bent & broke.
    If they want to sell more of these saws they better spend .20 cents more and make real metal gears and bracket.
    I am looking.
  • 16 Answers
SOURCE: oil for remington 3HP 16" chain saw.
The oil for an electric saw would only be for lubricating the bar, so you would only need to buy bar oil.
Posted on Jan 19, 2009
firesnake09
  • 2923 Answers
SOURCE: Owners Manual for a Remington 2.5 HP 16 '' Chain saw, Model EL-7
Kindly check this link for manual. Please select the correct model:
http://lawnandgarden.owneriq.net/manuals/mfg/remington/remington_chainsaw_product_list.html
Posted on Apr 18, 2009
dontbother10
  • 2220 Answers
SOURCE: repair parts for LNT-2 remington chainsaw
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "LNT-2" into the "Model #:" window, then clicked search.
  • Click the LNT-2 12 - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" I think you want item 12, 107713-01, Internal Gear
  • On the original view in the "Search for your parts by Part #:" type "107713-01" and click "Search"
  • Click the 107713-01 - USE REPLACEMENT PART # 122511-01 "View Part" link.
Results follow:
Part #: 122511-01 Price: $16.99
SPROCKET DRIVE GEAR BEARING KIT 747
3 piece replacement kit.
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Posted on Nov 10, 2009
dontbother10
  • 2220 Answers
SOURCE: I need a sprocket assembly for my EL* 107624-02
Afternoon Happy;
The obsolete chainsaw Gods smiled on you today, but there is a catch 22. You must purchase a repair kit to get the parts you need.
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
Part number 122511-01; SPECIALTY PARTS: SPROCKET GEAR (107713-01 SPROCKET GEAR, 075676 BEARING, 059606 DRIVE GEAR) (DSSP-SH); $16.99.
Are you aware RemingtonPower has ceased production? Soon eBay will be the only source for replacement parts.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 06, 2010
  • 760 Answers
SOURCE: I need a replacement motor for a Remington
You can buy this complete saw for about 75.00 on amazon. I've heard of others burning up the field and armature in this model saw. You can buy a homelite electric at Home Depot 50-75 depending on model. Doesn't seem like it would be worth fixing, only to have it burn up again. Sounds like it needs a thermal overload to prevent damage. GOOD LUCK1
Posted on Jul 01, 2010
Where can I order parts for my 16 inch electric Remington saw.
Usually any where that repairs lawn mowers, snowblowers, and chain saws or places that sell them like Sears.
May 13, 2010 | Remington 16" Electric Chain Saw
Chain doesn't engage when I turn the saw on. The saw kicks on, but the chain seems stuck. The sprocket?
There are a few of possibilities Millie. If the chain is excessively tight it will not turn. If the chain came off at speed and there are burrs on the drive links it may not turn (see the following please).
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
Last and most likely there is a stripped gear. Remington is no longer in production and parts are becoming difficult to find. Start here (the IPB is very useful for disassembly too):
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
If the part is NLA or Back Ordered above try here:
Master Distributors
If still NLA probably time for a new saw. Sorry.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 20, 2010 | Remington 16" Electric Chain Saw
Motor turns --sprocket or chain doesn't
I'm assuming your kill switch is not engaged, the front handle should be pulled to the rear. It's normal to have some damage on the sprocket from loose chains catching on the corner so I doubt you need a new one. The motor turns? I'm assuming you're talking about the clutch, and if the clutch spins but the chain does not it sounds like your bar may be damaged or as you said the sprocket may need to be replaced if it's seriously been misused.
Apr 15, 2010 | Remington 16" Electric Chain Saw
Afternoon Happy;
Master Distributors
Lou
Apr 06, 2010 | Remington 16" Electric Chain Saw
I have a 16'' electric chain saw, model 107625-02, and the channels in the cover over the sprocket broke so there is no way to maintain tension on the chain. Is that cover available for purchase?
I am uncertain of what is broken. Can you give me a "Item Number" from the Illustrated Parts Diagram?
Remington.com
  • Type "107625" into the "Search for your unit by Model:" window, then click search.
You can also do an Internet search for "Remington YourPartNumber".
Are you aware RemingtonPower is no longer in production? Soon eBay will be the sole source for replacement parts.
Please do not punish me because you are unhappy with RemingtonPower. My answer is very helpful but may not be the what you wanted to hear. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 07, 2010 | Remington Electric Chain Saw
Where do I get a Remington 16" EL8 chainsaw repaired for what seems to be a Gear Train Failure. I need a repair outlet near Beaverton, Oregon, 97007
Remington Service Center Locater
http://www.remingtonpowertools.com/service_locator.cgi
Remington.com
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
I think your model is 107625. A complete "SPROCKET DRIVE GEAR BEARING KIT 747" part number "122511-01" is listed at $16.99
Are you aware Remington is no longer in production and most replacement parts are exhausted? Before driving to any repair facility please contact them. If you undertake the repair your self please call 1 (800) 475-5660 (have saw within arm reach). Inspect your saw and verify my model number matches your saw.
Please do not punish my rating because you are unhappy with RemingtonPower. I provided a very helpful answer, perhaps not the one you wanted to hear. Sorry
Lou
Nov 30, 2009 | Remington 16" Electric Chain Saw
Repair parts for LNT-2 remington chainsaw
I went here:
Remington.com
Results follow:
Lou
Nov 10, 2009 | Remington Garden
Need sprocket (part #75752) for Remington 16", 3.25 hp electric chainsaw, model #100089-05, also numbers 71 34281 on box.
This should be part # 107713-01 - internal gear. Most likely used with a panhead shoulder screw part # 076905. Source: PartsFor.com
Oct 07, 2009 | Remington Electric Chain Saw
Apr 18, 2009 | Remington Garden
Remington Electric Chain Saw  Logo
244 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
