Question about Coby DVD-224 DVD Player
Connecting my DVD Player to my Digital Converter Box
I just bought the Isignia Converter Box for my 5-year-old Toshiba television. According to the instructions, I have to connect the converter to my DVD player then connect the DVD player to my television.
The DVD player is a Coby cheapie.
Connecting the converter to the player was easy, but I'm having trouble figuring out which jacks to use to connect the player to the television. The player is a progressive scan player and there are jacks for that. Do I use those to connect the player to the television?
I called Geek Squad and they told me to connect the player to television with the coaxial cable. On the back of the DVD player there is a jack labeled ''coaxial'' but the coaxial cable's plug doesn't fit. And according to the instruction book with the converter, this is not the best way to connect the box to the television anyway to get the best picture and sound.
Any suggestions?
  • landru58 Feb 01, 2009
    I understand matching the color of the plugs to the jacks, but my confusion is that three of the yellow/red/white jacks are used to connect the converter to the DVD. While the player has more yellow and red jacks, there is no other white jack. Do I just not connect the white cable from the player to the TV?
    I'm beginning to think I should've taken a friend's advice to just buy a new television...
  • 11,896 Answers
The jacks from the player go to the same colored jacks on tv. Then after jacks are connected, tv must be on channel AV or Input. that is the channel used by the jacks.
JUST MATCH UP THE COLORS.
Posted on Feb 01, 2009
  • Nate Stansfield
    Nate Stansfield Feb 01, 2009
    I PERSONALLY USE THE YELLOW, RED, & WHITE RCA JACKS.
    THE COAXIL CABLE THEY ARE TALKING ABOUT IS A REALLY THICK RCA JACK TYPE PLUGIN. IT LOOKS LIKE RCA JACK BUT ON THE INSIDE IS ACTUALLY COAXIL.
    JUST MAKE SURE THE CABLES ARE ATTACHED TO THE SAME COLORS FROM DVD TO TV AND YOU WILL BE FINE.
  • Nate Stansfield
    The yellow jacks are for the video
    the red and white jacks are for your sound.
    Tv should have 1 yellow, 1 red, 1 white jack.
    If the tv doesn't have this, then you can use the input jacks on vcr/dvd player and use the older coaxil to hook up dvd/vcr to tv.
    converter to dvd player, dvd player to tv
How to connect dvd player to tv
    1. If so you can get yourself a component cable and connect the DVD player to the TV using those plugs. Otherwise, you will need to get an RCA to HDMI converter.Nov 23, 2015
      Connecting old VHS/DVD Player to my Smart TV - Tom's ...
      www.tomsguide.com/.../id.../needed-connecting-vhs-dvd-player-smart.html
    Feedback
  1. 5 Easy Ways to Hook Up a DVD Player (with Pictures)
    www.wikihow.com/Hook-Up-a-DVD-Player
    wikiHowHooking up a DVD player to your TV will give you access to countless hours of movie-watching bliss, and most modern TVs and DVD players make the setup ...‎Setting Up your DVD Player - ‎Connecting with an HDMI Cable
    How to connect a standard DVD player to a TV - YouTube
    ? 2:57
    https://www.youtube.com/watch?v=8pARHjY8xoo
    Jul 5, 2011 - Uploaded by All About Home Electronics.com
    Lol I used my standard AV cables for the component, and I used an adapter to plug the audio into my speaker ...
Dec 30, 2015 | Televison & Video
Can you bypass a converter box by using a dvd player that has all the hookups?
you must read your owner manual, and see the diagrams attached, and proceed according. use the common sense. God bless you.
Sep 19, 2012 | Sony TV & Video 5-Disc Progressive Scan...
Connecting a toshiba sd-v392 to an old analog tv
Make sure your menu settings are correct audio outputs may have a setting for digital or analog sound output check that these are set up to analog or stereo output .Also try hooking the sound up direct to a stereo system or amp to be sure you have output! Also you may not be able to get your sound thru the convertor box!! Because the convertor is a reciever of digital signals not a line amp. for audio !! Hope this helps11 AAAAAAAAAAAAAE!!!! Swampratt200 ! Out!!
Jul 21, 2009 | Toshiba SD-V392 DVD Player/VCR
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Connecting DVD to cable only TV and Modulator box and Dish Networ
Without knowing the actual ports on each of these devices, all I can suggest is that have you tried connecting your DVD to the Dish box (thru VCR scart connection at the back of the Dish box) and then the Dish box into your modulator (and then modulator into your tv.
I have a similar system set up but we have a Sky Digital box here, no idea if its the same as a Dish box but im assuming so.
Jan 01, 2009 | GPX D1816 DVD Player
Dvds wont play
Check out the link I have posted below.
http://www.homemovie.com/compatibility.htm
according to the list, your in the 5% area of dvd players that won't read burned home made disks-DVD's
Sorry Pal your in the same boat as myself.
I have a Toshiba SD-2107 --- We're both aout of Luck :(
Looks like it's time to invest in a new DVD player.
Aug 05, 2008 | Toshiba SD-2109 DVD Player
I have purchased an HDD & DVD Player/Recprder with digital tuner;
That wil depend actually if its supported by your old TV, since on the old televisions there are video 2 and video 1, NTSC/PAL options. whats the TV brand? did you contact philips regarding the compatibility with the TV?
May 31, 2008 | Televison & Video
Using vcd/dvd combo with digital converter box
"Sounds" correct to me.  Are you going by the instructions that came with the converter box?  And, "ANT In" to the box from your antenna?
Apr 04, 2008 | Samsung DVD-V8600 DVD Player/VCR
Coby DVD-224 DVD Player Logo
629 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
