Start up not working on mac os10.4 - Computers & Internet
    Scholar:
  • 60 Answers
If you could be a little more descriptive about where your mac is stopping (what screen looks like) I could be of more assistance but here is a point to start at...
Start here...
Resolve startup issues and perform disk maintenance with Disk Utility and fsck
Mac OS X: How to start up in single-user or verbose mode
If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...
What is Safe Boot, Safe Mode?
Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack
Another excellent free tool for performing maintenance is Onyx (be sure to download the right version for your system). Install the package, then run it, it will check your drive and the structure, after this, click on the automation tab and check on everything for Maintenance, Clear Cache, Cleaning, and check on Reset -> LaunchServices database and Mail's Envelope Index. When it completes, restart. Repeat any time something seems flaky, if not try to run at least once a month.
Posted on Feb 02, 2009
How do I fix error code -8072 in OSX when trying to deleteitems fro Trash bin
If you can't empty the Trash on your Mac Try these solutions if you can't empty the Trash or move a file to the Trash.
If your Mac says that the file is in use
  1. Quit any app that you were using with the file, then empty the Trash.
  2. If that doesn't work, the app might have one or more background processes that are using the file. Restart your Mac, then empty the Trash.
  3. If that doesn't work, you might have a startup item or login item that is using the file. To temporarily prevent such items from opening automatically, start up in safe mode by holding down the Shift key while your Mac starts up. Then empty the Trash and restart your Mac normally.
If you can't delete the file for other reasons
  1. Start up from macOS Recovery by holding down Command-R while your Mac starts up.
  2. When the macOS Utilities window appears, select Disk Utility and click Continue.
  3. In Disk Utility, select the disk that contains the file that you want to delete. Then use the First Aid feature of Disk Utility to repair that disk.
  4. Quit Disk Utility, then restart your Mac and empty the Trash.
Jan 02, 2018 | Computers & Internet
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
My Mac 12" starts with a noise of the disk that
Check for a failing hard drive
Trying booting from the Mac OS X install disc. insert the Mac OS X install disc. press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
Dec 07, 2010 | Apple PowerBook G4 12" 1GHz w/ Combo Drive...
Power mac g5. Although I show Ethernet connected, i can't get network
You've established that you have a working physical connection. But your network addressing and routing is apparently not setting up.
The usual configuration is to set your Mac to "Using DHCP" and your router or other network interface to provide DHCP addressing. (If the address that shows up in the window on your Mac starts with "169..." it's a bogus address that means your DHCP isn't coming through.)
The most likely culprit here is your router. Take your router out of the chain or command entirely and plug your Mac directly into your network interface (assuming they are not the same box) and see if things suddenly start to work. If so, follow the configuration instructions that came with your router until you get a working connection through it.
Oct 18, 2010 | Apple Power Mac G5 Desktop
I have a Mac G4 desktop. It froze up so I restarted using the power button and when it came up it had a blinking question mark inside a folder. It will not do anything even after restarting several times....
This means the mac can not find the system to start up, you can try holding down the alt key as you start the mac, this may bring up a choice of systems to boot from if not then try holding down the shift key at startup, as this will boot without extensions loading. If none of this works then you need the startup dvd that came with the mac, if you dont have it the you need a retail copy of the mac os that will boot your mac , if its g4 then osx 10.3 or 10 .4 will work.
cheers
tech 240
Sep 13, 2010 | Apple iMac G4 Desktop
Macbook screen crashes when connected to projector
this is probably a projector setting
try checking the setting of both systems
May 09, 2010 | Apple MacBook Mac Notebook
Mac mini will not produce video
Hi, Sorry you are having problems,
Well, that sounds pretty bad. Does the Mac make the start-up sound when you turn it on?
Does the little light in front turn on ?
Do you hear the hard drive spinning up and working to boot the mac ?
So, if all these questions are answered Yes.... sounds like the video connection has blown.
If you say the Mac is almost new, Apple should cover this with the one year warranty.
Good luck.
Oct 31, 2008 | Computers & Internet
I have had 3 failures in downloading the renewal on Mac OS10,4 Tiger
please go ahead and contact the symantec customer care service it is free toll free number 1800 745 6061 they process the immediate refund for you.
Oct 22, 2008 | Symantec Norton AntiVirus For Macintosh...
Mac Mini G4 Flickering Screen at Start Up
Did you check the wires?  Sometimes if you pull one loose it flickers.
Aug 13, 2008 | Apple Mac mini G4 Desktop
Computers & Internet Logo
199 people viewed this question
David Payne
David Payne
