Can this be repaired
You didn't mention the treadmill model but most treadmills will have a diagnostic code appear if this type of thing happens. If you are not standing on the treadmill does the belt move just a little?
My guess is if you do not have an error code then the belt may be trying to move and is either obstructed or loose. If you are getting a code then there is usually a belt (like a timing belt) that goes from the motor to the drive roller and it is probably broken or has just popped off. You'll need to remove the cover to see this - CAUTION - unplug the treadmill if you are going to remove the cover!
