Question about Peavey Audio Players & Recorders
One out of the two microphones is intermittent.
(431FX Peavey Equalizer) with FLS
It cuts out at times even though snapping the mike with your finger causes audio output at the speaker. It seems to work better for some people over others. I notice the input level padding is right to the lowest setting. Does the equalizer have a VOX cct that requires a certain level of audio to trigger the amp on? Arranging for another mike for testing but was wandering if you can offer any suggestions? Thanks in advance.
Ken
    Genius:
  • 1,175 Answers
Hi Ken....
I just fixed one of those but not for the same issue.
The manual is on the peavey site (archived)
That will tell you if there's a VOX ckt inside.
If opening the case doesnt scare you, open it ( UNPLUGGED) and reseat the ICs(integrated curcuits) that are socketed
Posted on Feb 16, 2009
I need a new channel changing Mike for a Realistic TRC 476. The cord for the Mike was cut and even though repairs were done the radio just scans through every channel very quickly and constantly.
You should check the new cable wiring connections. There is a resistor in that microphone that connects to the channel button circuit, it is (electrically) between switch 5 (up) and pin 3. If this not present then it may be causing your issue, IT is also possible that the diode for that circuit (located on the main board) got damaged when the cord was cut. diagram: http://www.cbtricks.com/radios/realistic/trc_476/476_print.htm
Oct 10, 2016 | Radio Communications
Can i use a peavey PVi2 mic on my peavey renown 400?
No you need a preamp for the microphone found on audio mixers. You will not get good sound from it even if you do buy a mini mixer to provide a preamp for the mic. I would suggest a pa like the ones in this link. Most of them have built in mixers (with preamps) also.
Portable PA Systems Sweetwater com
Apr 12, 2016 | Peavey Audio Players & Recorders
Must open up a Peavey DPM3 SE to repalce battery. Have removed nearly every screw and bolt on the unit, no luck. Any suggestions?
Most likely secured with plastic snaps as well. PLEASE research though B-4 tugging with too much force as you could break the case. I often find additional screws hidden under labels and/or rubber/plastic feet on bottom. Good luck.
Apr 17, 2014 | Audio Players & Recorders
Peavey Valveking head strange feedback.
Sounds like one of your tubes going bad and becoming microphonic...
Google "Microphonic Tube" for additional info.
Oct 25, 2012 | Peavey Valveking Vk100 Guitar Head
How much price value
The Escort's integrated design allows for ease of transportation, while its user-friendly controls offer ease of operation, making it the perfect choice for schools, churches, civic organizations and small musical groups. The Escort features dual two-way speakers driven by a five-channel, 300 Watt stereo powered mixer, making it ideal for both vocal and musical applications. The system also includes a PV®i unidirectional (cardioid pattern) dynamic microphone, two folding speaker stands and all necessary connecting cables. Among many professional features, the mixer includes 60mm faders, a five-band graphic equalizer with FLS® (Feedback Locating System) and digital reverb. The carrying case provides storage for all the system componets with ample room for additional mics and cables. This clever design incorporates the speakers into the package, allowing the unit to be easily carried or pulled along on its luggage-style wheels.
Specification
  • Convenient package with luggage-style wheels
  • Two-way speaker system with 10" woofer and piezoelectric horn
  • Five-channel powered mixer
  • Four XLR mic inputs with 15 V phantom power
  • Two stereo line inputs
  • 60 mm faders
  • High quality digital reverb
  • 300 Watts output power (150 Watts per channel) with DDT™
  • Five-band graphic equalizer with FLS
  • Two folding speaker stands
  • One PV®i cardioid dynamic microphone with cable
  • Two 25' speaker cables
  • Storage compartments for microphones, cables and accessories
  • Weight Packed: 64.00 lb(29.029 kg)
  • Width Packed: 16.62 x Depth Packed: 39.75 x Height Packed: 17.62
£499.00.
$649.99
$649.99
May 05, 2011 | Peavey Escort 2000 Microphone
Sound cuts out
Hi Darren.
I suspect you may be right about the eq here, though you probably have had it sorted by now.
I came across this thread because I was searching for a fix to my R-231 and was hoping you might be able to help me if you found a fix. I'm persisting with this one as I can't really get another just now and it seems that it's not a major issue. I managed to get a good signal out of it when I ran it without the ground connected on output???
Anyway, any info I would greatly appreciate,
Thanks, Rob dronno@live.com.
May 20, 2010 | Digi-Tech DOD-Digitech 231 - 31 Band Per...
The settings on my Peavey Q215FX dual 15 band graphic equalizer w/fls have been changed and I am unsure where they were set at and what the correct settings should be.
Assuming that you eq is installed in your system correctly add a source like a cd of the type of music you will be putting through the system. Now starting at 0 on all frequencies adjust to your liking. Try to avoid going above 0 as much as possible because this will be adding to that particular frequency and could damage your speakers if done incorrectly.
If there is too much bass lower your sliders to the left. If there is not enough highs boost the sliders to the right up to about half way then start decreasing the bass to get the desired effect. Small increments is important.
I found that if you go to your local music store the people there are more than willing to help you.
Dec 31, 2009 | Peavey EQ215FX Home Equalizer
Mic snaps and cracks when you move the cords. Have changed cords several times. Something may be loose in the mic.
Try tightening the set screw in the tail of the mic near the XLR connector. I that doesn't work it's got to be some loose internal connection.
Apr 12, 2009 | Peavey PVM 480 Professional Microphone
Old peavey amp cutting out
time to resolder everything, got a good 10 power eye loupe?
Mar 09, 2009 | Peavey EQ215FX Home Equalizer
How to hook the eq up??
take output from left and right from equalizer and go to line in any two channels inputs in peavey mixing console and adjust your level with faders and other control knobs.
Mar 02, 2008 | Phonic PEQ3400 2x15-band Graphic Equalizer...
135 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
