Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Sears Coldspot 17 frostless freezer not defrosting
The serial number is 106.628440 and was working fine up to last year. Now it forms a thick layer of ice on the back wall of the freezer. It also does not seem to keep the softer items like ice cream bars etc. totally frozen...but the ice and frozen meats keep.
  • swbaxtergrou Feb 02, 2009
    Yesterday I found the defrost timer is not working properly. I rotated it clockwise until it clicked, putting it into defrost mode. I emptied out everything and took the back panel off over the coils and removed the ice from around the coils. Cleaned up the inside and turned back on...now it seems to be running all the time and the inside temperature is at -5 degrees F. When I adjust the temperature control from 1 to 2 I can hear it click on but the inside fan seems to be running all the time.
  • purplehand Apr 10, 2009
    Problem ends up with frigerator not getting enough air flow from the freezer flow. Freezer is still cold but frigerator slows air flow. Coils
    are freezing up in the middle of the freezer. Took off panels but it
    seems to be happening on a faster pace.
  • 323 Answers
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Posted on May 12, 2009
  • Jose Maria Vega
    Jose Maria Vega Jan 27, 2015
    Thanks a lot, Dan. I buy a new trasnformer, and now Im dessassembly for to recognize the other parts in damage.
  • Jose Maria Vega
    I have a new regulator of voltage, and I have cleaned the magnetic rubber to tyhe door.
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
After freezer was moved not getting cold
Unplug the unit and leave it undisturbed for 24 hours. Plug the unit back in again and see if it will come to temp.
Jun 02, 2009 | Freezers
Sears ColdSpot model number 106 7649314
REplace the fan. The fan is most likely bent and will continue to have problems until it is replaced. You can get it at repairclinic.com
May 30, 2009 | Freezers
Ice forming very fast on top shelf only
You said you checked the seal but one thing you can try to be double sure the seal is tight put a thin layer of vaseline along the entire seal it will fill in any gaps and you can be sure it is sealing completely.
Jan 05, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Dec 03, 2008 | Kenmore Freezer 14.1 cu. ft. Upright...
Kenmore frostless 19 temp. control knob
i've pulled up the service diagram for it and there's no thermostat or temperature control but there's a limit sensor inside the freezer I'm sure that such sensor is failing and when it defrosts, it stays on to long, and the whole 15 min defrost cycles goes on causing the freezer to warm up, delaying the freezing process. I'm almost sure that the limit is going.
Jun 10, 2008 | Kenmore Freezers
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
1,959 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
