Question about Acer Aspire 5600 Series 5630-6951 Laptop
My acer 5630 laptop does not boot up
The acer splash screen comes on but does not boot up it keeps saying a disk read error as acurred press alt+ctrl+del to restart but it just repeats itself. ive tried alt+f10 & f 8 but doesnt work. just get a beeping sound f 2 works when splash screen starts up pressed on load default setting but still the same
  • dworrall46 Feb 02, 2009
    forgot to say back up disk as been lost but cheers 4 that
  • wwanderer Feb 07, 2009
    I have exactly the same problem, I have been told it is a damaged hard disk and will have to be replaced. Again I have no back up disks I have been unable to produce them from the Acer recovery prog.
    wwanderer
  • 153 Answers
Try reinstalling the OS with your restore disks. It might be that you have HDD failure in which case you would need to replace the HDD.
Posted on Feb 02, 2009
Trying to recover from acer restore cds but keeps coming up with the above eror number and telling me to restart computer
Hello
Can you read the that recovery disk in another computer/laptop? If yes,put the CD into the tray When you boot your system hit f12, then select your USB cdrom, and it should boot then.
If no,you have to check the BIOS settings to ensure that "CD-ROM Drive" is set as the first boot device, otherwise the PC will ignore the disc.
press F2 at the acer splash-screen during the boot process, or when you see "Press F2 to enter setup" at the bottom of the screen.
On the main BIOS screen there is a menu along the top.
Use arrow key to highlight 'BOOT' in the menu bar.
Now you see "Boot Priority Order"
Yours probably has "IDE 0" as first boot device,
and "CD/DVD as second boot device.
The first boot device (IDE 0) is already highlighted.
Press 'F6' to swap them round, so that first boot device is
"CD/DVD"
Now press 'F10'
Highlight "YES" at the prompt (may already be highlighted) and press <Enter>
PC will reboot, this time from the CD/DVD drive first.
You can leave the BIOS set like that permanently so you don't have to go through all that process again next time, just don't leave a bootable disc in the drive unless you really want to boot from it.
Apr 12, 2011 | Computers & Internet
I'm getting a screen that says "A disk read error
this problem caused by error connection at hard disk, your hard disk can not read by your computer
to fix this problem you need to open your laptop then disconnect your hard disk from laptop, and connect again
and turn on your laptop
the problem like this usually found at computer with sata hard disk connection
i hope this helpful
Apr 04, 2011 | Acer Computers & Internet
My acer laptop keeps saying put in the boot disk. it did not come with one
I assume that the Acer was working and now it gets this error.
This error message can be cause by a few things. please click on this link and follow my instructions to fix this problem :-
http://www.fixya.com/support/r6244569-no_bootable_device
Oct 06, 2010 | Acer Aspire 5315 Notebook
Possible hard drive failure
Does the splash screen come up? Most of the time if it is your hard drive the ACER splash screen will come up and then a Hard disk 0 error after that. If nothing appears on the screen then you have a bigger issue.
Is there any noise at all (Fan, hard drive spinning)? If so try hooking it to a external monitor to see if there is any movement. You might have a problem with your LCD.
Apr 20, 2010 | Acer Aspire One PC Notebook
Blue screen on acer extensa 5630 laptop it says its my intel display driver
Try rebooting the computer in safe mode with networking...this is usually done by tapping the F8 key while the manufacturers splash screen shows up for a few seconds. Once the multi-boot screen comes up scroll to safe mode with networking and click ok. Once the computer boots up, it will probably be using a generic video driver to show a picture, go to acer's support site and download a fresh driver, the link is below....good luck. when you click the link, make sure you pick what operating system you are using to get the correct driver. click on drivers > notebook > aspire > 5630 > choose operating system.
http://gd.panam.acer.com/home/
Oct 07, 2009 | Computers & Internet
Blue screen error while installing XP in acer 5630 with 4 gb ram
Boot your computer with winxp disk then follow the procedure.
Press enter for install new xp then you see partition delete all partition then create again then install xp in first partition try this 3 to 4 times so that error not comes .you can do it.
Let me know if you need more assistanse.
Thanks.
Sep 21, 2009 | Acer Extensa 5630-6806 Notebook
Won't boot up on first try
Whenever you do get it booted into windows, run the command prompt and in there run "chkdsk /f". That will check your disk for errors and repair them. Yours sounds like a boot sector problem, chkdsk should be able to fix that.
Jul 24, 2009 | Acer Extensa 5630-6806 Notebook
Helpneed
A few things you can do.reinstall os.repair os or checkdisk all of which require xp disk(or whatever os disk )
to check disk.boot up from os disk(xp,whatever)
screen displays install or repair
select repair which then takes you you a dos platform (black screen c:/promt
type in chkdsk (exactly as is)
system will run program and if any errors try to repair.
To repair system:-boot up with os disk
in choices install or repair select install
after diagnose system stsate os already exist install or repair ...
select repair..if you want to reinstall fresh copy choose install instead of repair.
repair does as it says and leaves previosly installed software intact..
install wipes all data and installs new copy which has to be registered again within 30 days.
Nov 30, 2008 | Acer LXA3706003 Notebook
Read hard disk error keeps coming up, computer does not recognise the [player
acer laptop 5290 won't boot up.. keeps saying "disk read error occurred" cannot get anywhere but to that screen saying that.
Jul 26, 2008 | Archos 104 MP3 Player
Acer Aspire 5630 PC Notebook loading prob
for this 5630 model drivers or available in acer website
now i am working in acer laptop service center
http://support.acer-euro.com/drivers/notebook/as_5630.html
Oct 23, 2007 | Acer Aspire 5630 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
193 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
