Question about Badger Basket Starter Spray Gun Hobby Set
Total Novice Bought an Iwata Revolution airbrush and the instructions are almost worthless for a beginner. Where do I put the paint? What do all of the nozzle adjustment do? Stuff like that. Help if you can.
  • 50 Answers
I suggest that you go to the Library and look up how to airbrush. The paint goes into the cup. Nozzle adjustments are learned as you go, for desired results. Good luck
Posted on Feb 04, 2009
Airbrush stopped spraying paint
Is the paint tube clear at the venturi?
Feb 11, 2015 | Iwata Neo for CN Gravity-Feed Airbrush
Cap blowing off
Try this link: http://anestiwata.com/product/airbrushes/
then click your model, the manual is right there, next to product description.
Nov 02, 2012 | ANEST IWATA IWA4292 Hi-Line Kustom HP-TH...
I am using an iwata eclipse cs airbrush with an iwata compressor. the comopressor seems to be working fine when power, but the airbrush is not getting and air. when i push down for air release, nothing...
Air brushes us a Theory called a "venturi" in where air pressure lowers the pressure where the paint is kept and causes it to go out the nozzle. I would try seeing if there is an obstruction in the hoses to the brush and confirm that the compressor is moving air. If none of these things are an issue also while cleaning the parts may give the appearance that the item is clean then try soaking them over night in paint thinner and replacing the O-rings and gaskets.
Apr 27, 2011 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Air compressor regulator
hi my iwata powerjet lite shut down.theres power but no performance.it only gets used for prob ten hours a week,somtimes weeks without use.is this common and expansive to repair.thank you.re ****.
May 01, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Water coming out airbush from hose
An in-line water separator should be used before the supply line, a good air filter wouldn't hurt either.
Apr 23, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Bubbles in color cup of airbrush
I assume you have adjusted the nozzle... On my unit, there is a SMALL hole in the cap for the cups to let in air above the paint. Also OFTEN the paint must be thinned to use in an airbrush. Since you havent been able to draw water even, thinning is NOT the problem.
The airbrush aspirates the paint by Bernouli's principle, that is where there is higher velocity of a fluid, there is a lower pressure. The nozzle creates that and the adjustment is important. On mine which is a "Wren", I think by Binks there is a conical piece that the paint comes out of with a throttling needle. This has the be unscrewed to open the paint path and adjust it. The air flows at high speed around this cone creating a vacuum.
The headline says "Eclipse" but that is a gravity feed so I suspect that is the old Fixya problem of having incomplete choices to pick from.
Feb 18, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
My iwata hpc is pushing air back through the paint cup
Try replacing cup gasket first then clean all inlets and outlets completely, check that all valves operate properally, and all seals and o-rings are in good condition. Clean and lubricate adjustment fluid valve.
Jun 16, 2009 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Need a new paasche spray gun for bigger jobs
Anest-Iwata brand spray equipment has the most versatile line of airbrushes on the market. Im sure you will find one to meet your needs. well worth the money, it's all I spray
http://www.airbrush-iwata.com/
http://www.tcpglobal.com/airbrushdepot/iwata.aspx
check it out!!
Apr 07, 2009 | Air Tools & Compressors
Badger Basket Starter Spray Gun Hobby Set Logo
158 people viewed this question
Top Badger Basket Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Badger Basket Air Tool and Compressor Expert? Answer questions, earn points and help others
