Question about NetGear WGR614 Wireless Router
Cannot connect to the internet through my IPOD My network doesnt have Router or DNS
Whats the model of ur ipod plz ??
Posted on Feb 02, 2009
Connected to access point but internet cannot be found
check the DNS settings that your router is passing.
some routers dont always talk the same language (they are suppose too thought) with other manfactures hardware. it might not be passing the DNS info to the computer.
get the DNS from the router (http://192.168.1.1) then place that into windows. network connections => device name => properties => TCP/IP v4 => bottom box where it says DNS.
if the router doesnt have DNS settings to give plug the cables in and reset the router and modem.
Jun 11, 2010 | Linksys (WMP54GS) 802.11g/b Wireless...
The DNS error on my PS3 from LINKSYS
your wireless network should be configured to NOT broadcast the SID and a WEP key. Then after entering the address of the router manually in the network setup on the PS3, you will able to obtain an ip address from the router
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
Ipod touch 2nd gen
Can you please tell us more specifically what the main problem is? To my understanding, it is a wireless connectivity problem with your iPod Touch. It's just a simple to check. Go to Wireless Network Settings or Wi-Fi settings of your iPod. Make sure it can see or detect the signal from your 2Wire. You'll just need to manually connect to it and enternet WEP key or Network key which you can find at the bottom or side of your 2Wire modem. That's the 10-digit code. If you have it entered, check the TCP/IP settings of your iPod, make sure the IP Address is set to Automatic or DHCP as well as the DNS Servers. That should fix it.
Jul 25, 2009 | 2wire 1800HG Router (RG1800HG00)
My ipod touch is connected but won't use the internet.
Your router is blocking the iPod Touch from using the wireless.  Go into your router settings (depends on your router) and find the security or firewall for the wireless page.  You will need to enter in the MAC address of the iPod Touch (found in Settings>General>About - it is labeled as Wi-Fi address).
Jun 07, 2009 | Apple iPod touch
Laptop showing connected but not connecting to Mozzila firefpx or explore
You should have right settings. Or the firewall of the router doesnt block your computer. Could be MAC blocking or tweak your DNS setting. In your LAN setting TCP/IP properties set your setting for DNS in automatic. Or you set it manually. Try to check your ISP DNS. check also if your router DHCP setting is enabled.
If you are in Vista and using wifi. Goto Wireless Network Adapter under Control Panel>Network sharing Center>click manage Network Service click adapter properties>highlight Internet Protocol version 4>click properties set auto or set it manually. you can also just set manually the DNS.
May 31, 2009 | Linksys Computers & Internet
Windows xp wont connect to internet
Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
If it is not working, check the default gateway address on working computer and use it instead.
Feb 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Connecting Ipod touch 8(GB) to Wi-fi
I want to tell you that there might be two problems for your concern.
1. Your router is not working properly
2. Your Ipod Touch is not working properly
But it might be possible that both devices working fine just the compatibility issue.
First of all i can suggest you that you can upgrade the firmware for your router.
Then you can reconfigure your wireless setting on your router.
Then tried to put static ip on your ipod touch in the network setting option
IP address: 192.168.0.15
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.0.1
Primary DNS: 192.168.0.1
Secondary DNS: 4.2.2.2
Then tried again to connect wirelessly with your ipod touch make sure you dont required to add mac address for you ipod touch and also you can click on the option called "Wireless Access Point"
Then you can see the option " Turn Access Control On" you can uncheck this option.
Try again i believe that will resolve your concern.
Thanks & Regards
Jaspreet Singh Saini
Jan 06, 2009 | NetGear RangeMax WPN824 Wireless Router...
Can't connect my router to my Ipod touch?
ok do this if it is already showing your router up on your portable device but it has that security lock and you are unable to join or need a password which u dont know lol go to that network and on the top push forget this network. than go back and click on for other location. than for the name put in your router name usually 5 characters long make sure u use capitalization cuz its case sensitive. than select what kind of key u have it should say right on the side of your wireless router. than type the key in usually a wep key and u should be set to join it if it doesnt auto matically do soo
Dec 20, 2008 | Zyxel P660HW-D1 Router
NetGear WGR614 Wireless Router Logo
23 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
