Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Refrig.motor will not start
Frigidaire Gallery Model # FRS 26 ZGHWO.
House power was turned off then when turned back on, motor would not start
  • Frigidaire Master
  • 19,396 Answers
Leave the unit unplugged , or without power, and try restard, if it does not restart, the control circuit board may have been damaged after power surge
Posted on Feb 01, 2009
How do I unlock my Frigidaire gallery refrige
Examine the control panel and locate the "Control Lock" button, sometimes located next to the "Light On-Off" button.
  • Press and hold the "Control Lock" button for a few seconds until the small red LED goes out.
  • Make your changes to the refrigerator's controls, or use the water and ice dispenser. Repeat step 2 to restore the control lock.
  • Oct 18, 2016 | Frigidaire Refrigerators
    Unplug Frigidaire model FRS 26 th Plug it back up Ice maker Has not worked Freezer and food storage is not real cold
    ice makers will not work above 5 degrees Fahrenheit
    sounds like you got something else wrong do you know if the refrigerator has been defrosting is this an American refrigerator? usually model numbers are about 10 digits long I'm going to look your number but if you like some help just let me know
    Appliance 911 Sea Breeze
    Aug 04, 2015 | Frigidaire Refrigerators
    Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
    check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
    Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
    Serial number
    there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
    Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
    Water dispenser and ice maker not working
    Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
    Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
    Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
    Try replacing the filters, they might be slowing the water flow.
    Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
    Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
    The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
    Nov 23, 2007 | Frigidaire Side by Side Refrigerator 26...
    Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
