Question about Vulcan SG44D Gas Double Oven
CONVERT FROM NATURAL GAS TO PROPANE GAS
WE HAVE MOVED THE DOUBLE CONVECTION OVEN TO A NEW LOCATION THAT USES PROPANE GAS. WE WERE TOLD WE NEEDED CERTAIN PARTS ADDED OR CHANGED TO CONVERT TO PROPANE GAS USE. WHAT SHOULD WE DO? ALSO, PROVIDE A RECOMMENDATION OF SOMEONE TO DO THE WORK. THANKS PAT
  • Anonymous Mar 21, 2014
    what parts are need to convert Blodgett 1048 Pizza ovens from naural gas to propane
  • 4,655 Answers
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Posted on Feb 01, 2009
Can you converta lincoln impinger from natural gas to propane
Yes you need to go to your gas company and ask them to convert it to LP use they will change burner orfis hrom Natural use to LP use.
Jan 06, 2012 | Lincoln Conveyor Oven - 1133-000-A
My Kenmore propane oven is taking long then time needed to bake something
A very common problem when gas(both propane and natural) oven takes longer to heat properly is going to be a weak igniter . Since its weak its not fully opening the gas valve and not enough gas is flowing to produce the proper flame size/heat. By replacing the oven igniter it will heat as its supposed to .
GENE
Sep 24, 2011 | Kenmore Ovens
Need to know how to convert from natural gas to propane. vulcan oven,.. model 60XL77R. thanks!
I am looking to change from propane to gas. Willing to swap parts
Mar 16, 2011 | Ovens
The gas orfices were changed to propane from natural gas. What size of gas orfices does this oven require? Or will any licensed gas fitter know this and have them on hand to convert this oven back to...
Sorry to read about your problem, I hope this helps you out.
you will have to contact southbend for that info..it is not a common practice to convert these units.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Southbend SLGS12SC Gas Single Oven
Natural or propane?
get numbers off gas valve. go to http://www.blodgett.com/convection_home.htm
and see if your oven is there. If you have any issues, send me the numbers. Get any you can off of id of oven, gas valve or anything you can. I'll find you an answer.
Nov 22, 2009 | Blodgett (ZEPHAIREG-DOUB) Double Oven
I have a Blodgette/Zephaire Convection Oven. I need a part# for a conversion kit from nat gas to propane. Model# Zephaire-G-L.
I went online to the Blodgette Company. I went to service request and asked the same question. I recieved an answer via e-mail, the items and part numbers need. I then contacted a local distributor for the items needed.
Oct 09, 2009 | Blodgett (ZEPHAIREG-DOUB) Double Oven
I have a gas oven. The flame burns yellow and leaves too much soot on the wall near the flame. Is there a way to clean the element thing? Dave
I am not sure. However, people in our area of sc, have had burner problems because a local utility added propane to their natural gas because they got it a bargain. guy
Jun 10, 2009 | Frigidaire FGB24S5A Gas Single Oven
Convert from propane to natural gas
it should have come with different orfices. some for propane and some for nat gas. if not go to any repair shop and they will have them.
Jun 07, 2009 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Why won't my oven ignite? Vulcan model GC04c
i can get you the error code but dont have my manual at the time.a couple things to check.do you here the clicking sound of the ignitor that ignites the gas?when you installed the regulator are you sure its on right?you should see an arrow on the regulator body and it should be pointing to the oven.also you need 10 inches of water colum (gas pressure)with a propane system where as natural you need less,regardless ill be in touch.
Jan 16, 2008 | Vulcan Convection Oven - VC44EC-208-1
Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Dec 20, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
Vulcan SG44D Gas Double Oven Logo
926 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Treefrog15
Treefrog15
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
