Question about Sony Playstation 3 (PS3) Console
Ps3 usb ports not working
The 2 usb ports on my ps3 40gb have stopped working. Do you have any suggestions on how i can go about fixing it myself? I am pretty technically able and have no problems with opening up the system; but i have no experience with soldering.
Thanks so much!
I think your ribbon for the ports might of came unplugged check it out!
Posted on Feb 20, 2009
  • anandtoora
    anandtoora Nov 23, 2012
    Can you actually help about the ribbon problem? Like tell me if it ain't there please?
Ps3 stopped reconizeing usb ports
Most common issue (assuming it hasn't been modded) is simply dirty connections. With the power off and unplugged (say saying to protect myself so someone doesn't get electrocuted), use compressed air to spray out thee ports. From there, dip q-tips in isopropyl (rubbing) alcohol and gently clean the metal connections on both the PS3 and device that is being connected. There is a chance that one of the tiny metal connectors have broken off. If the other port is still working, you could pick up a hub which is a device that has one USB end that plugs into the PS3 but multiple input ports to allow multiple devices.
Sep 17, 2013 | Sony Playstation 3 (PS3) Console
My USB ports both don't work they stopped working and I tried to restore my PS3 to factory setting and that popped up I can not sync because o the messed up ports money is extremely tight and can't af
This is a common problem Sony basically will not support and will make you buy a new system. The pins for the USB ports are made so cheaply you can't even find a replacement from anywhere except Sony...
There is only one way to make this work:
1. Turn off PS3
2. Plug in controller to USB port
3. Turn on PS3
USB should work if something is in upon bootup, if this does not solve your problem I hate to break it to you, but a new PS3 it is my friend...
Nov 14, 2012 | Video Game Consoles & Games
One of my usb ports on my ps3 slim stopped working
Your usb port might have stopped working, but you can still use it to charge other devices like phones, mp3,etc. However, if the damaged port cannot even charge a device, there is nothing you can do apart from managing the other ports. On the other hand, if the port can still charge devices but cannot detect them, you just have to manage the other hub, and use the damaged on to charge only, okay.
Apr 25, 2011 | Sony Playstation 3 (PS3) Console
I have a logitech ps3 controller that is wireless. i plug in the usb into a usb port on the playstation and it still does not work. how do i fix this?
A couple possible issues here.
The first is that the batteries on your controller are dead. You may want to try changing them to see if that fixes your problem.
The second is that your USB receiver may not be seated properly or the port on your PS3 may not be working with the USB receiver. Try a few different ports to see if that changes anything.
The third is that you have a hardware failure in either your controller or USB receiver. If that's the case then you'll need to get a replacement from Logitech.
Mar 25, 2011 | Logitech Cordless Precision Controller for...
My ps3 controller is is not working when i press a button the red light above the D/mode button blinks a couple of times then stops the adapter thing that goes in the ps3 usb port is just bilnking non stop...
i had one of these, it broke too, the problem was the usb dongle, the usb connector is very cheap and breaks easy, i did manage to fix mine but it didnt last very long, if you are good at soldering or know someone who is you can try re-soldering the four pins on the usb connector inside the usb dongle, they may have cracked and become disconected from the small circuit board, you should be able to see if there are any broken connections if you look through a magnifyer and gently move the usb lug up and down.
Jan 24, 2011 | Logitech Cordless Precision Controller for...
My PS3 won't reconize any of my controllers, putting the cable in works, it find the controller, but when I unplug te cable the lights start blinking again and I can't use the controller, what to do?
Hmmm. It sounds like either your PS3's Bluetooth controller is on the fritz, or all of your controllers are on the fritz. Since I doubt ALL of your controllers are malfunctioning, I am betting it's your PS3. I suggest having a friend with a working controller stop by and test his controller against your PS3. IF your friend's controller works, then you know that the PS3's Bluetooth controller is working.
Second step is to check to see if the USB cable is transmitting a trickle charge to the controller. Again, using your friend's controller (make sure he brings his own USB cable with him), try charging his controller with HIS cable first. If after 10 minutes of playing with the controller plugged into the PS3 via USB, you unplug it and the controller still works, then the problem is most likely your own USB cable (it's apparently damaged in some way). Now run down the controller's battery and try recharging it with YOUR USB cable. If it fails to charge, then you know that all you need is a new cable. Just in case, make sure you test EACH of your USB ports. A simple replacement will cost you around $10.
Otherwise, your PS3's UBS port(s) are not properly working and you should send in your PS3 for repairs. As stated above, test each of the USB ports on your PS3. My 60GB one has 4 USB ports, so I would test all 4 of them before sending in the PS3. Then, if you want it repaired, make notes of which port(s) is(are) malfunctioning and send it to an authorized PS3 repair center.
Dec 24, 2010 | Sony BD Remote Control for Playstation 3
PS3 USB ports won't work
First of all you can't watch movies off a pendrive anyways=p and as to your controller not charging try a different chord or a new paddle
May 27, 2009 | Sony Playstation 3 (PS3) Console
PS3 does not recognise the Logitech Driving Force Pro Wheel
hapened to me with a usb drive plug it in,plug it out,plug it back in and leave it for about 10 mins and it should work...thats what i do when my usbdrive dont work
Apr 13, 2008 | Sony Playstation 3 (PS3) Console
All I could say is have a person who is really smart with technology take your Ps3 aapart and check the diodes on your fuse board (green plate that has a buncha little things on it). check to see if your diodes could be burnt or possobly loose. unless you can take it apart but have troubles putting it back together i wouldent try it. have a really smart person fix it. not a scientist or some guy from a company...justi make sure they no wat they are doing. I messed up my USBs by having a short in my keyboard. it tells me to plug in my controler but It wont read my controlers. theres a 92% chance its somthing wrong with my USB ports. I hope this helps you out.
Feb 10, 2008 | Sony Playstation 3 (PS3) Console
PS3 USB Ports
how old is your ps3? if less than a year dont open or it will cancel your warranty.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,538 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
