Question about Fujitsu Siemens AMILO Pro V2000 Notebook
No power Battery went low, I shut down the laptop, and put it on charge, now I can,t get any power at all, even with the power lead plugged into the side of the laptop charging the battery. Model is - Fujitsu siemens AMILO Pro v2030
  • Fujitsu Siemens Master
  • 4,806 Answers
Hi there
Take the battery out and try to power the machine up on AC only,
Post back with the results please
Posted on Feb 01, 2009
I have my laptop n4030 not charging.
Does the battery need replacing? Did you reboot the machine? Shut down, unplug, remove battery, plug in , reboot. Any change?
Dec 26, 2012 | Dell Computers & Internet
VISTA PC DOES NOT STAT laptop vista battery went down to 10% Vista was shut down and was connected to power supply try several times to start the pc but it just does not start if pc is shut does the...
The battery continues to charge if the computer is off. The computer probably won't turn on because the battery is so low. It might not be charging because the power cord might not be plugged into a wall plug that is on. The plug might be on a switch. Find a plug that you know for sure that is on then plug it in there and try again.
Jul 29, 2011 | Computers & Internet
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
Y laptop will only work on mains power. When I put in the battery, laptop shuts down.
This is either a problem with the battery or the motherboard.
If you can find someone with a similar Toshiba you can try their battery in your laptop, if it works then it's obviously a problem with the battery itself and you'll need to order a new one.
If it doesn't work then it's a motherboard problem which can be pretty expensive to fix (hopefully you're still under warranty)
Aug 21, 2010 | Toshiba Computers & Internet
TOSHIBA U400 running VISTA; When I am on battery and get low i plug in so i can continue working but even though the lighted icons on the laptop show it is plugged in and charging and the toolbar icons...
Yes it is, seems there is some problem with the power state detection and changing of the load mode. Might by a physical problem, so I am not sure you can fix it.
At least check your power plan details and see if there is any error with the ACPI devices in the device manager.
In general, if you use the laptop when plugged, you should take out the battery to maximize the battery life (prevents useless load cycles).
Also configure Windows to optimize battery usage.
Apr 24, 2010 | Toshiba Satellite Pro U400-S1001V Notebook
Acer aspire 2920z is automatically shutdown only message appear warning critical battery low and then shutdown
Sounds like your battery is faulty and not charging. Try replacing the battery or just use the mains lead with the battery removed. If this keeps happening replace the system board
Feb 23, 2010 | Acer Aspire 5610-4648 Notebook
Battery not charging . light comes on power supply but batterlife went down even thogh it was plugged in. now now enough power even to start up
Try turning off your computer, removing the battery for 10-20 minutes, put it back in, and turn it on/charge it. If this doesnt work it sounds like a short in either your charging cord or your battery.
If its still under a warranty then send it to your dealer.
Aug 28, 2009 | Computers & Internet
VAIO VGN-FS 770W wont turn on
Try to remove the AC power and then the battery. then plug in the power without the battery. Turn-on the Laptop if it starts then slowly put the battery back after it boots in windows. Check if the battery is charging.
Hope this helps.
Dec 01, 2008 | Computers & Internet
Attempting to load but suddenly shut off..
It sounds like the laptop was in a screen off state (happens when it is left on but not used for a while).  When you pushed the power button it went to shutdown, and notified you that someone (you) is still logged on.  Any unsaved work could be lost, hence the warning.
Five minutes later when you went to switch it back on, the laptop coincidently must be low on battery, to the point where it will not stay on, and exhibits the problem you are experiencing now.  Try plugging in to power and make sure that the battery is charging, and try again.
Nov 06, 2008 | EliteGroup ECS A535 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
463 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
