Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
Liitle white dots on the screen
It looked like a spot on the tv, but when i went to wipe, it wasn't spots, just areas of no color.
  • 4 Answers
Seen an LCD like this before, sometimes it is from the display not repairable
Posted on Apr 08, 2009
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 27, 2014 | NEC Lamp for NP215 Projector
White dots on screen
http://www.metacafe.com/watch/yt-XeIOwN1CIp8/samsung_mitsubishi_toshiba_dlp_hd_tv_repair_tips_black_white_dots_on_tv_problems_bad_dlp_chip/
I believe it is the digital projection chip that is beginning to fail. Causing white and black spots to appear. To repair this may cost more than a new tv. If you want to attempt it yourself check out the above link. Hope this helps
Jan 12, 2014 | Samsung Hl61a750 61" LED Powered DLP HDTV
My tv has small white dots of lights in most of the screen can this be fixed.
Ensure your input device is not causing this, by changing the TV input to a different video device. Then, look for any loose contacts on the RC cable or input cable. If nothing works, better refer it to a qualified service technician.
Jul 19, 2012 | Philips 42MF531D 42 in. LCD Television
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
GREY SPOTS ON BACK OF SCREEN NOTICEABLE WITH WHITE
Hi if your tv is a dlp it might be an issue with the DMD board Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
May 03, 2010 | Televison & Video
White spots on TV Screen
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.</span>
Apr 20, 2010 | Televison & Video
Hitachi 55vs69a yellow blob in center
you most likely have a bad light engine.
Aug 20, 2009 | Televison & Video
Numerous white spots on Smasung DLP TV
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
May 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
Yellow Spot dead center on screen
most likely the yellow dot is due to a burn in the picture on the "green" lens. It's not removable because it's burned it, but you can try cleaning it because sometimes, dots are caused by dirt. The worst that can occur is that if the dot is permanant.
Feb 14, 2006 | RCA MM61110 61" Rear Projection Television
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
155 people viewed this question
Henry  Thomas
Henry Thomas
