Question about Hotpoint Ultima WF860 Front Load Washer
Fo5 is flashing on my washing machine1600 spin 6 kg load.its half full with water please how can i fix it?
  • Alz40 Feb 03, 2009
    Hi did what you suggested and flooded my kitchen in the process lol !!
    But F-05 still comes up and we managed to get 17 pence and a piece of sticky tape out of the filter ! Can you suggest any thing else ?
    Thanks
  • Hotpoint Master
  • 3,463 Answers
Error code F05 is indicating that the water level switch is stuck on full, this is probably due to a blocked filter..
To clean filter, proceed as follows.
Remove lower panel at rear of washer.
Locate and remove the large black hose fastened to the bottom of the tub.
Drain the water from hose into a container of some sort.
Remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is securely fastened back on.
This should solve the prob.
Pleas rate my fixya solution.
Thanks.
Posted on Feb 02, 2009
Error code F08 FLASHING WILL NOT SPIN
The pressure switch is stuck and the machine thinks it is full of water. You need to remove the top, look for the pressure switch and unplug the hose on it and blow air through the hose. Then replace the hose on the switch. It looks like this: http://www.yourspares.co.uk/parts/hotpoint/washing-machines/wt960p/parts/ys56011/hotpoint-wt960p-pressure-switch-spares-C00194160.aspx
Feb 06, 2016 | Hotpoint Ultima WT960P Washer Front...
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
F05 keeps coming up on my ultima 860 hotpoint 1600 spin w/m,we cant find manual,what is problem?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Fo5 is a pressure switch fault; areas to check are pressure chamber for blockage, pressure pipe sump and pump. Click on a link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
Sud message Bosch washing machine
ur using too much soap rinse and spin and use less soapwhen u wash
Feb 19, 2010 | Bosch Washing Machines
Machine wont empty and all lights flashing with a fo5 code
Fo5 indicates pressure switch jammed on full.
To rectify the problem, do the following.
Remove lower rear panel of washer.
Remove large black hose from bottom of drum
Remove and clean plastic filter inside hose.
Remove hose from pump, and check for blockage or obstruction here as well .
Please rate my solution.
Thankyou.
Jan 24, 2010 | Hotpoint Washing Machines
Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Nov 18, 2008 | Hoover AAA160 Front Load Washer
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Washing machine won't drain water nor spin
You have either a clog in your water pump or it has broke.Most the time it can be fixed by removing the 2 hoses attached and remove all debris.Then make sure it is still working.This will correct the light flashing problem at the same time. Please rate this ~!!!
Sep 09, 2008 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
341 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
