I have a whirpool washer front loader...AWOD 5526 It is brand new and the first recomended cycle the clean pump light flashed and stoped the cycle, so I refered to the manual drained the reamining water manually and made sure the filture was clean and rotor free moving and resumed and the same light keeps stopping the cycle and states clean pump??
  • 15,935 Answers
It appears your pump has failed or the inlet strainer needs cleaning in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
Whirlpool washer beeps
Whirpool front loaders have a trap for the evacuator rinse pump in the front lower right corner. If it is clogged the pump will be stuck and the machine will not operate in any mode.
Oct 24, 2017 | Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Whirpool error h23
h23 is a fault code , refer to your machine handbook for explanation of these codes.
Nov 09, 2009 | Washing Machines
Amana Touchmatic Heavy Duty Washer Filter Light Flashing
I have the same washer unit and I purchased my washer new in 1989. The flashing filter light is normal. If the light doesn't flash, than the water filter is plugged up. The water filter is self cleaning each time the water empties. You can take off the front panel(two screws at the bottom and the top disengages with metal clips. The water filter in at the bottom on the right, white plastic housing. There is a drive belt from the motor that powers the pump. When the washer goes into the spin cycle, the motor changes rotation direction and the pump works in reverse, thus flushing out the lint that may have been captured during the agitation cycle. I hope this helps.
Mar 14, 2009 | Amana Washing Machines
WHIRPOOL FRONT LOADER WASHER NOT SPINNING
Not pumping out the water - if the washer cannot pump out the water, the washer will not be able to spin...check the pump for not pumping.
Door not locking - if the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the consol.
Broken wires at one of the out off balance switches or a bad switch itself.
A fairly common trouble maker has been a burnt diode on the main control board. See diode R11.
f this has happened to your main control board ( in the consol ) , the wax motor in the door lock assembly is drawing too much hydro and must be replacing at the same time as the control board. The wax motor can check, appear and test ok but will fail when working throughout the cycle.
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
