Connect hdd to motherboard write : reboot and select proper boot device or insert boot media. And in BIOS invisible hdd
I've read this problem due to new hardware interferences with desktop computers, all they had to do is change a few pins around on the harddrives.. since this is a laptop, and is quite difficult and dodgy to access the hardware, the only other suggestion is to reinstall windows with a recovery disk, or windows CD-ROM.
Hope this helps :)
SOURCE: computer beeping and saying reboot and select proper boot device
When you reboot, go to BIOS, restore factory BIOS settings. If that doesn't help, you'll need to reinstall your OS.
SOURCE: I picked up a twinhead durabook r15d, upon
The good: Affordable; great battery life; impact protection; spill-proof keyboard; magnesium-alloy frame.
The bad: Still no flash card reader; heavy; no double-layer DVD+R support.
The bottom line: The Durabook will surely appeal to those who need a rugged notebook to withstand the elements outdoors.
Make sure the HDD is showing in the BIOS, you may have to instal an OS
Testimonial: "thanks for the help!"
SOURCE: Can not start HP mini
the hard disk must have gone bad, so when you go to bios go to diagnostics and run a test on hard drive, most probably if it fails , u need to replace the hard disk so call hp and u can replace the same
SOURCE: Error message says PXE-E61:media test failure
HELP ME!!! mine says the same thing but hen it says operating system not found.
help help help!
sorry did not write in that category. I have a desktop pc
not detecting
