Can not install firewire card due to computer not finding softwa
I have put in the firewire card in the slot, and started the installation wizard. As I go through the process the message appears as...can not install this hardware. this hardware was not installed because we can not find the necessary hardware
(the cd rom is inserted)
nexxtech1394 card model# n3pfwpc
I have windows xp
bought from circuit city, and id not rteturnable.
Any help would be great
Greg C
  • gregceiley Feb 02, 2009
    Thanks for trying, but after a good solid seating the computer responded with the sane message.
    Greg
  • 31 Answers
Did you check to make sure the card is seated correctly? Try removing and reseating and make sure the card is level and firmly inserted in the slot and repeat the driver installation.
Posted on Feb 01, 2009
  • tlagrassa Feb 03, 2009
    Did you try a different slot?
Can't get the metal tab off the back to install a firewire port
http://www.fixya.com/support/t16489047-39_t_get_metal_tab_off_back_install
Alandoni post the Model Number of the Gateway Desktop PC
Post back in a Comment.
http://support.gateway.com/us/en/support/default.aspx
I'm going to assume you are trying to install a Firewire adapter card.
They make Firewire adapter cards that fit a long white PCI slot, on the motherboard,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3264905&CatId=511
http://en.wikipedia.org/wiki/PCI_local_bus
,and a Firewire adapter card that fits a PCI-Express x1 slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4624358&CatId=510
http://en.wikipedia.org/wiki/PCI_Express
http://en.wikipedia.org/wiki/PCI_Express#Form_factors
[NOTE* Color of connector does NOT matter. Blue, Black, Pink with Yellow polka dots............doesn't matter ]
Do I assume you have the PCI-Express x1 version, and there is no PCI-Express x1 slot on the motherboard?
You are also having problems opening the cover, that keeps the brackets of add-on expansion cards in place.
How about posting the Model Number of the Gateway Desktop PC?
This is found on the back of the desktop computer, next to the Windows product key; or up on the side of the computer tower.
I will look to see how to open that cover, and what expansion slots you have on your motherboard. Then post back in a Comment.
Regards,
joecoolvette
Feb 10, 2013 | Gateway DX Computers & Internet
Replace wireless card
Computer components have become more reliable than ever. Although many parts are now integrated onto the motherboard, it may become necessary to add or replace a sound, video, or network card due to component failure or the need for improvement. Integrated components can be left in place, and the problem solved by installing a second card into an available PCI slot. If a component such as a network card fails it can be replaced easily and inexpensively.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Turn off the computer and inspect the case. Remove the screws that hold on the removable side access panel. Remove the panel and lay the computer on the other side. Locate the network card. Inspect the rear of the computer to locate the network port. If it is a PCI-style card it will be the card with the single connection port on the rear face of the card. If it is a fixed part of the motherboard it will be located near the connectors for the mouse, keyboard, and USB ports. If it's a PCI card, remove the retaining screw and remove the card. Remove the PCI network card if present. Leave the case open and stand the computer back upright. Connect a keyboard, mouse, and monitor and restart it. Open the new network card and remove the installation CD. Insert the CD in the computer and follow the installation instructions. Shut the computer down again after the installation is finished. Lay the computer back down. Install the new network card in any available PCI slot. Replace the case and stand the computer back up. Hook up the keyboard, mouse, monitor, and a network connection. Restart the computer. Accept the default installation settings when the Windows Found New Hardware Wizard launches. Select No on the screen asking you to check for drivers online if it appears. The wizard should continue and find the newly installed drivers. Complete the Found New Hardware Wizard. Reboot the computer even if it does not ask you to. Open Internet Explorer, Firefox, or your favorite browser once the computer is running again. Ensure connectivity by trying several different websites. Hope this helps.
b>
Dec 07, 2012 | Sony VAIO VPCEE31FX Notebook
b>
Dec 07, 2012 | Sony VAIO VGN-FS660P/W Notebook
I have a new ASUS G73SW-A1 laptop with no firewire port. Can I add a firewire port. Can I install a Belkin Firewire adapter into the cardbus? Does it even have a cardbus? There is some kind of card slot on...
You can add a firewire card to on of your existing PCIMCI slot.
Please see, as an example
HERE
You may purchase these cards online at nearly any electronic/computer shop.
May 04, 2011 | Computers & Internet
How can I add firewire to my HP s5730f slimline when the pci express slots are blocked? Is there a pci card I can use to add firewire?
Hi, yes, you should be able to add a firewire card that goes into a spare PCI slot inside your computer. I have provided some links for you to have a look at.
http://shop.ebay.co.uk/items/__pci+firewire+card_W0QQ_dmdZ2?rvr_id=225057574812&crlp=2874201279_284591_284611&UA=WVI7&GUID=55fa9e2812f0a5aac495e335fff88dad&agid=1381991649&tm_kw=pci+firewire+card&siteid=3&MT_ID=11&tt_encode=raw&keyword=pci+firewire+card&geo_id=21&ff4=284591_284611
http://www.amazon.co.uk/s/?ie=UTF8&keywords=firewire+800+card&tag=googhydr-21&index=aps&hvadid=6983137693&ref=pd_sl_5zy4ohv55t_b
http://www.ebuyer.com/store/Peripherals/cat/USB-----Firewire-----I---O-&-HBA/subcat/Firewire-IEEE--1394-Cards
When you say your pci express slots are blocked, do you mean that you have a card, likely a video card, already installed in your pci express slot? You should have available pci slots anyway and you can purchase a fireward card and install it yourself. If you are unsure about this then you can do a search on youtube as there are lots of how to videos on there regarding this type of installation. Good luck. Andrew
Apr 14, 2011 | HEWLETT-PACKARD PAVILION SLIMLINE S5730F...
Would like to install a firewire card in Gateway DX-4822 - don't know how - can you help please?
Buy a PCI card like
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124015&cm_re=firewire_pci_card-_-15-124-015-_-Product
open the side panel of your pc and install the card in a free PCI slot, start the pc , close the New Hardware wizard and launch the installer from the disk that came with the board.
Aug 12, 2010 | Gateway DX482201 (PTGA002002) PC Desktop
Firewire PCI card not recognized
Sometimes, when one is inserting a card, one does not push it firmly in place. If some contacts are not well established, the card may not be recognized.
Hope it helps.
Aug 22, 2009 | HP Compaq d530 SFF PC Desktop
Jvc problem
I think you can by using the firewire cable, connect it to the the slot indicated by i (for iLink) DV on the camcorder and connect it ot the computer firwire port. A firewire slot is available if a Firewire card is isntalled on your computer. I am in the process of installing a Firewire Card (starting from $15.00 and upwards) hopefully everything works out.
Oct 28, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Im trying to download viedo from my camcorder to my lap top and its says i need to install a certain software
a firewire cable will probably work better than a usb connection ( assuming your laptop has a firewire connector ) for video editing ;
Jul 31, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Installing a firewire pci Card onto my HP Compaq dc5000 Small Form Factor PC
Hi, Actually there are various types of customized firewire connections for your computer. Here is a link to view some products that might work with your computer. http://www.firewire-1394.com/firewire-usb-combo.htm Also, there are different sizes of PCI cards available. You have to shop around to find an apropriate size.
May 04, 2007 | HP Compaq dc5000 PC Desktop
Computers & Internet Logo
David Payne
David Payne
