Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Admiral washing machine wont spin
Seems to do everything even drains just wont spin.ive tried to spin by hand when empty but seems jammed,worked fine till i moved it a few feet to fix the dryer lol,when i put it back and went to use it ,was ok then made a stranged noise.if it is the motor how much am i looking at to replace in canada?thanks
  • happiey89 Feb 13, 2009
    Same issue can't seem to find any help... Anyone??
Its your timer knob
Posted on Aug 08, 2009
Replace the belt...
Posted on Mar 10, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from
Why won't my washer spin or drain? - Kenmore 110 Series ...'t+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain -
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
Hi, My Admiral 560 heavy duty washing machine has stopped washing and won't spin dry iether , it fills empties and gose through the motions of everything , but will not wash or spinn dry, what is that...
I had a similar problem with a maytag and it was the lid switch. I put a new one in and it worked just fine. Hope this works for you. Cost about 10 dollars.
Dec 24, 2010 | Admiral Washing Machines
Beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Jul 01, 2009 | Washing Machines
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Dec 21, 2007 | Admiral AW22 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
405 people viewed this question
Sal De
 Brian Main
Brian Main
