Question about HP PSC 1610 All-In-One InkJet Printer
When i copy or scan anything the whole page comes out black
Was told by hp that it was a malfunction of the scanner glass, and it is not repairable, and I should buy a new printer. is this right, or are they just trying to get me to buy another printer?
  • gshoney Mar 08, 2009
    when i copy or scan anything the whole page comes out black.
  • Burton Whalen May 11, 2010
    HP 1610 printer produce totally black pages
    Genius:
  • 2,120 Answers
A new scanner assembly will cost you as much as a new printer.
Posted on Feb 01, 2009
Why does my HP Photosmart C6150 All-in-One only prints/scans full black page
Open the scanner cover and check on you to copy double-check scanner moves when the light comes from the scanner and see if it sees the glass as if it would be messy to be opened and cleaned
Jul 22, 2014 | HP Photosmart C6150 Wireless All-in-one...
Black line on copy
Lines on scanned or copied pages is usually caused by ink and trash on the scanner glass. Check the glass on your printer for something blocking the light on the scanner. Here is a link to an article about this issue and where to clean.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
Aug 21, 2012 | HP Officejet 5610 All-In-One InkJet...
I have a wide black stripe when scanning pictures or making copies. Printing is fine.
Sounds like there is either something on the glass, under the glass or there is some malfunction with the scanner itself. You will probably need to take it in for repair.
Oct 28, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Problem for HP Color LaserJet 8500 Printer Black line on the left side printed page while making copy on HP. This problem occurs only while loading the page on the top tray HP 8500 printer. No black line...
This is usually caused by something on the scanner glass. Check for dried ink or correction fluid on the scanner glass. We have a short article about solving this type of issue posted here: http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 28, 2010 | HP LaserJet 8500 Color Printer
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
Copying and scanning problem
The tech support at HP said its a hardware issue, especially if the following test results in a black page:
1) Open cover
2) Push scan button
if the bulb doesn't come on or the page is still black its a hardware issue.
Nov 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
HP PSC 1610 All-In-One InkJet Printer Logo
128 people viewed this question
Ben Johnson
