Question about Radio Communications
I want to know about the range with handheld cb radios
    Problem Solver:
  • 17 Answers
It depends on lots of factors....
First, the output power of your radio. Many claim 5watts output, but when measured on an accurate SWR / power meter, they are usually closer to 4 watts. Also, they usually output full power only with external power supply, not internal batteries.
Second, the antenna. If you are using a "rubber duck" helical, range will be at its minimum. If it has a quarter (1/4) wave telescopic whip (about 2 meters!) then that would be better.
If it has a socket for external antennas, then a (1/4) quarter wave car mag mount on something metal and 1/4 wave in radius this would be pretty good, especially if mounted above any local restrictions like buildings and walls.
The ultimate would be a half 1/2 wave antenna, mounted at least 1/2 wave (5 meters!) above ground, on a scaffoling pole or similar at least 1/2 wave long (5 meters).
The station you are speaking to also has a lot to do with range, if they have a good station, then range will be better.
With 5 watts, at the right time of day, with the right antenna, and under the right conditions, CB can reach across the globe! Yes really.
You need to post more info on the type of set up you have.
Hope this helps
M3ODQ
Posted on Feb 02, 2009
Handheld Radio Shack CB radio TRC-230 I can hear people but no one can hear me
First, lets make sure that the unit does transmit. Get a power meter and see how much power it transmits. If no power is being radiated, you need to have a technician check out the unit.
If you have power then pick a less crowded time to test out if anyone can hear you. Other people with more powerful equipments can only be a problem when you are transmitting on the same channel and both of you happen to transmit at the same time all the time. Chances are remote that this is your problem. Good luck. es
Mar 23, 2013 | Radio Communications
How can i get the frequency 130.00mhz - 150.00mhz from 75-822?
No. CB radios operate in the 27 MHz range and cannot be modified for out of band operation.
Feb 16, 2011 | Midland 75-822 40-Channels Handheld CB...
I just have Uniden Por510XL (used) but don't know how to set the channel (programming) so it can match with my handheld radio (i use motorola GP2000)
well a GP2000 has a Frequency range of 136 - 174 MHz, 403-440 MHz or 435-480mhz
a uniden pro 510XL is a 27 mhz radio as far as i know...
Dec 09, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Does not seem to have very limited range
Hi, my name is John. Welcome to FixYa. All of the handheld,s have very short range. Try to extend the antenna as far as it will go and depending on your location, it should get out a little further..good luck. Thanks for choosing FixYa... John
Oct 27, 2010 | Cobra HH 38 WX 40-Channels Handheld CB...
Dose it work good like i live in a prtty good nabor hood dose it get good distance will it conect withe other bigger cb radios
Typically, this type of handheld has a useful range of approximately 1-2 miles. This distance will be increased with other radios being mobiles and base stations. Distances of 5 miles is possible if the other person has a good base station antenna. I would not expect much from the stock rubber ducky antenna.
JTRadiojunkie
Aug 30, 2010 | Maxon HCB-10C CB Radio
What is the range of the maxon hcb-10 model. miles or kilometers will do
It is between 4 - 7 miles.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 26, 2010 | Maxon HCB-10 40-Channels Handheld CB Radio
I need help please
Make sure you have the CTTCS codes the same on each radio! Also PMR446 radio's wont be able to talk to GMRS radio's
Aug 30, 2009 | Midland 75-822 40-Channels Handheld CB...
I have a Maxon handheld cb - it squeals when keyed can not talk.
sounds like you are getting a feedback squeal.. try taking a wire and attaching to you handheld and grounding it to something.. that might work.. i know i have to have my mic on my cb grounded to my radio or i get a feedback squeal...
Jan 02, 2009 | Maxon HCB-10C CB Radio
Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 31, 2008 | Cobra 75 WX ST 40-Channels Handheld CB...
Hand held cb
installed ones, are you refering to base stations? these rigs are more powerful because of the higher wattage outputs and stable installed aerials. :) your handheld can put out as much as 5 watts of power.
May 18, 2008 | Radio Shack Pro-95 Handheld Scanner
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
