Question about Sony Xplod XM-554ZR Car Audio Amplifier
I have a 2 channel sony xplod amp. Would like to play songs through USB onto it.
  • 125 Answers
You can buy an audio adapter for USB or Ipod ready kit from this address at wholesale dealer cost its cheap and easy look under accessories.
Posted on Feb 04, 2009
I got Sony Xplod XM-ZR704 700W 4/3/2-Channel Car Stereo Amplifier and 12" sub. it play good for continuous 2 hours but after that starts tripping and goes on off. i checked all wires and connections.
Amp is probably over heating. Make sure the ohm load of speaker is good for that amp. This amp is not really built to handle a bridged 2 ohm load. Make sure ground wire is clean and tight to the body chassis.
May 18, 2012 | Sony Xplod XM-ZR704 700W 4/3/2-Channel Car...
Is the sony xplod cdx-gt71w able to support a subwoofer without another amp
Sure is.
The sony is bridgable as follows:
  • 100W x 4 @ 4 Ohm
  • 100W x 2 + 250W x 1 @ at 4 Ohm
  • This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
    The single sub channel is created by bridging channels 3 & 4
    Dec 22, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
    I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
    You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
    May 28, 2010 | Sony XM-ZR1252 Car Audio Amplifier
    I have an sony xplod 4 channel 600 watt amp
    First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
    May 06, 2010 | Rockford Fosgate P112-200 Car Subwoofer
    3/4 channels have blown
    Proably only sony can help you out with that..then agian make sure you play with the amp HP LP FULL if it has check your fuses also.
    Jun 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
    What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
    Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
    I had the same problem as you. The problem is the wiring from your speakers to your amp TRIPLE check your wiring. Make sure that none of them got disconnected or connected to the wrong wire.
    Mar 30, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
    Bridge a two channel amp
    i the search bar type in....subwoofer wiring diagram....then go to crutchfield and it shows you your options.......
    Jan 28, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Sony Xplod 2-Channel 1000 Watt Amplifier trouble shooting
    What's the model number of the amp?
    What speakers do you have on the amp?
    Are the speakers moving significantly at high volume?
    Sep 13, 2008 | Car Audio & Video
    Sony Xplod XM-554ZR Car Audio Amplifier Logo
    42 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Larry Stiles
    Larry Stiles
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
