Question about Samsung HCL4715W 47" Rear Projection Television
Blue convergence,3-D Wavy primary colors
Dropped a tv tray 10 feet away from tv, it shook the tv and now its 3-d and the reds blues and yellows crisscross each other in a wavy Pattern
its a 2002 Serial # 31ETB01540Y 47"
  • Samsung Master
  • 5,138 Answers
Set is 7yrs old look for cracked board.
Posted on Feb 17, 2009
I was given a tv with a color problem. The main colors are yellow, blue and red. There are blue shadows behind the yellow words. Is this a major problem?
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 28, 2010 | Hitachi 46BX01B 46" Rear Projection...
Convergence problem TV won't let me align the
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jun 12, 2010 | Panasonic PT-53WX52 53" Rear Projection...
Wavy picture with blue and purple color.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
3-D picture with color lines
Seems TV has dry/ cold solder joints (loos connections) in convergence out section.
Please check cold/ dry solder joints in convergence out section in TV, specially on pins of convergence out ICs. resolder these solder joints and all would be fine.
Sep 28, 2009 | Sony KP-57HW40 57" Rear Projection...
Red, Green convergence lines are wavy
*Screen Looks 3-D
*Colors wont align
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
My colors all of a sudden went out of wack
Is there an advanced convergence setup anywhere in the menu where the screen displays a grid? If so, you might want to get into that and move along the grid to each section that looks off. Adjust until the color falls behind the gridline, and move on to the next. It can be a time-consuming process, but should take care of your convergence issues.
Jan 20, 2009 | Toshiba 55H70 55" Rear Projection...
Color suddenly switches to 3 separate colors and is wavy
Replace STK ICS Both of them they are your convergence ICs will Have Part Number on them 2 big black ICs and there is Low ohm resistors that should be replaced also.rk42,46,48,50,52,54,60 62.
Repair Cost in Shop 325.00 and up.
Jan 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 24, 2007 | Televison & Video
Samsung HCL4715W 47" Rear Projection Television Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
