Question about Yamaha YSP-1100 Digital Sound Projector Black Speaker
Do I set my DVD output into the 1100 on Bitstream or PCM ?
The connection is via an optical audio cord from a Panasonic Blu-ray disc player (DMP-BD35). The 1100 has no HDMI connectors.
  • 24 Answers
If you truly have a blu-ray player, it will have a HDMI port.
Posted on Feb 04, 2009
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
How to get audio on Phillips blu ray
If playing direct in to the TV, make sure the player's audio menu is set to "mixdown to PCM" or just PCM rather than Bitstream. The reason is that most Blu-rays contain audio in DTS format. But very few TVs can handle the raw Bitstreams DTS data feed. Let the player do the conversion to an audio format that the TV understands. PCM is pretty universal. It'll be just stereo, but that's okay because your TV probably can't do much more than that anyway.
Aug 04, 2014 | Philips Blu-ray Disc Player with Wi-Fi -...
I have a LG LCD TV 26LX2R and I recently bought a Sony Blu-Ray BCP-S580. If i connect them via Composite or Component cables i get ok video and audio. But when i connect them via HDMI i get excellent image...
I can't speak on whether or not the apple tv has such a setting but the Bluray players does. You go into the bluray player's settings and change the audio output.Your choices should be 2 ch possibly hdmi, bitstream, pcm, and auto. Try hdmi, 2 ch, and pcm because if you have it on auto you might not get sound via an hdmi cable and it's probably not bitstream but try bitstream if none of the others work.
Sep 20, 2011 | LG 26LX2R 26 in. HD-Ready LCD TV
I have an LG HT752 TP home cinema system. I recently bought a Panasonic DMP BD 65 blu ray player and connected to LG system via optic cable. Problem is that when playing blu ray discs on the Panasonic...
That shouldn't happen, what kind of cable are you using? you should try an hdmi cable. its electronic so it either works or doesn't and there shouldn't be any lag at all.
Feb 28, 2011 | Televison & Video
Technics SA-DX940 Digital optical audio input
When you say you have sound from the BD prior to disc load... where (TV and/or receiver)? Initial wake-up audio is usually 2-channel.
Describe the optical audio connection input to the receiver and any other audio paths that are attached.
Do you have other multichannel sources you could use to test this, like a cable TV box?
There's an obscure setting in the receiver called PCM Fix (on Page 21). Give that a look.
Jun 07, 2010 | Technics SA-DX940
Does the Insignia ns-2brdvd digital opt. output work with HDMI
Below is what your manual says abour it. From hardware perspective, when you have a disc in there the optical audio driver is active and so is the HDMI audio. To verify, lift the lid on the optical interface and you will see a red or blue light on the inside. Don't look directly at it! View from the side.Plug that into your home theater system, select that input on your home theater and you should be good to go.
Insignia NS-BRDVD Blu-ray Disc Player
www.insignia-products.com
Connecting a digital audio optical system
To connect a digital audio optical system:
1Make sure that your player and the TV are
turned off.
2Connect one end of a digital audio optical
cable (not provided) to the DIGITAL OUT
(PCM/BITSTREAM) OPTICAL jack on the
back of your player.
3Connect the other end of the cable to the
DIGITAL AUDIO OPTICAL INPUT jack on
the digital audio system.
Aug 11, 2017 | Televison & Video
Only decoding in pro-logic
go in blue ray dvd menu as dvd is playing and select the audio out formatt u wann use has to be on 6.1 or least 5.1 digital not 2.o ch ok and u may be seding the digital with the hdmi outs not both be hard for it to do doe syour tv had digital opti out run that to reivciver on digital input ok tell blue ray options menu also digital oput bitrate ok
Jan 18, 2008 | Sony STR-DE835 Receiver
Yamaha YSP-1100 Digital Sound Projector Black Speaker Logo
208 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
