Question about Texas Instruments TI-85 Calculator
I have a TI-84 Plus and want to know how to convert DMS degrees into decimal degrees and vice versa. I also need to know how to find the sin and cosine and tangent of same.
  • 35 Answers
Like the TI-85, it would be in the MATH menu.
Posted on Feb 24, 2009
After you have enter the inverse of sin into the calculator, how do you get the degree of that angle?
Make sure the calculator is set to degrees. Press MODE and ensure that "DEGREE" is highlighted on the third line. Press 2ND QUIT to get out of the mode screen.
To calculate the inverse sine of 42/57, press
2ND SIN^-1 4 2 / 5 7 ENTER
The arcsine of 42/57 is about 47.46 degrees.
Apr 15, 2014 | Texas Instruments TI-84 Plus Silver...
How do i enter 50deg,25minutes,23seconds into a casio fx-9750 plus
In Run>Mat press the OPTN key, Then F6:> to move to the next page of options. You will see the ANGL tab as on the screen capture (above F5 key.
Press F5. You will see what follows.
Type in 50, press the F4 key, 25 then F4, 23 then F4. Press EXE. you get the result in decimal degrees as on the screen capture. To convert from DMS to D.D, or from D.D to DMS, vice-versa, press the F5 key
Jan 05, 2013 | Casio FX-9750GPlus Calculator
How do i go from dms to decimal degrees with my ti-30x IIs
Press the key that is marked with a small circle, an apostrophe, and a double quotation mark. That is the DMS key. You can use it to convert from Decimal degress to DMS and back.
Oct 27, 2011 | Texas Instruments TI-30XA Calculator
When I hit dms function the answer comes out wrong the degree minutes = the degree and the seconds = the minutes how do I change it TI-84 Silver
At first, you have to use DEGREE mode and after that you can convert your angles into DMS mode. See captured image below
Oct 05, 2011 | Texas Instruments TI-84 Plus Calculator
I know how to convert between decimal degress and degrees, minutes, seconds, but how do you enter degrees, minutes, and seconds directly?
Enter it as DD.MMSS and then press 2nd [DMS-DD] to convert it to decimal for further calculations.
For example, to enter 21 degrees 34 minutes 45 seconds, enter 21.3445 then press 2nd [DMS-DD].
May 12, 2011 | Texas Instruments TI-30XA Calculator
How do I get from degrees to radians? For some reason my TI-84 will not convert degrees to radians.
Press the [MODE] key to access the mode comfiguration screen .
Set angle unit to to radian (see above)
Enter angle value in Decimal degrees only, use the [2nd][ANGLE] key sequence to have access to the degree symbol. The degree symbol must imperatively appear at the end of the angle value.
Here are some examples
If you use angle values in DMS, it will not be converted to radians, but to decimal degrees.
If you omit the degree symbol there is no conversion.
A general formula is Pi radians =180 degrees
Feb 10, 2010 | Texas Instruments TI-84 Plus Calculator
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
How do I find degrees minutes and seconds on my ti 84 plus?
On this family of calculators, you do as follows
  1. Enter the first number (degrees), ex:15
  2. Press [2nd][APPS] (ANGLE) to access the Angle functions
  3. Select [1: degree symbol] [ENTER]
  4. Main screen shows 15 deg
  5. Enter the minutes, ex 25
  6. Press [2nd] [APPS](ANGLE) to access Angle functions
  7. Select [2:' apostrophe] [ENTER]
  8. Screen echoes 15 deg 25'
  9. Enter the seconds number, ex 32
  10. Press [ALPHA][+] (") to access the double quotation mark.
  11. Screen echoes 15 deg 25' 32"
  12. Press [ENTER]
  13. Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
Converting degrees and minutes and seconds to radians
With the TI8x/TI8xPlus you can enter an angle in degrees (Angle mode must be set to degrees) and convert it into DMS representation the following way. Exemple
18.675 [2nd][ANGLE][4] [ENTER] gives 18deg 40' 30''
If Angle [MODE] is set to degrees you can enter a number in radians and convert it into degrees. Exemple How many degrees are ther in 1rad ?
[1][2nd][ANGLE][3] display 1 with a small r as superscrit. Pressing [ENTER] yields 57.29577951
To convert 1rad into DMS, takes a little effort but can be done: you have
to convert radians to degrees and the result [ANS] into DMS.
You cannot use an angle written in DMS in any calculation.
But if you want to convert an angle from degrees to radians enter your number and divide by 57.29577951
Hope it helps
Sep 02, 2009 | Texas Instruments TI-84 Plus Calculator
Degrees, minutes, seconds converted to decimal degrees
No DMS button
1degree 22.25 minutes
2nd Math F3 1 F1 22 f3 15 f3 enter
Sep 05, 2008 | Texas Instruments TI-85 Calculator
Texas Instruments TI-85 Calculator Logo
260 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
