I have coolsat 7100 reciever. On the front of the box panel it wouldn't let me go up or down or turn power off.
  • 77 Answers
It sounds like you got a bad flash. Try to re-flash it with factory firmware 3 times, then reload your current firmware and see if the problem is fixed.
Posted on Feb 16, 2009
Cpu not powering up
sometimes the front bessel of the case comes loose a little and doesn't allow enough contact for the button to work. check there are no gaps around the front panel piece of your PC. after that there are 5 other things that could be wrong. bad motherboard, bad CPU, short in cable on motherboard, Try holding down power button for 10 seconds and see if that helps.. you might have to do it twice. you could need a new motherboard kit.
Dec 03, 2013 | Dell Studio Computers & Internet
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
Jul 20, 2009 | 1999 GMC Jimmy
Coolsat 6000 fta connection
if your hooking it up just to ur TV you would need The RCA Video Cable, Video- yellow, Red - right, white is left,Witch is printed on the back of the box, this would go into the output an go in to TV input
Hope it works
Oct 17, 2008 | Toshiba SD-H400
FTA tv
usb connection in back of router or the reciever front panel
May 16, 2008 | Linksys Wireless-G WRT54G Router
My Coolsat 5000 won't power up. It has dim red light(s) on the front when turned on, but that's it.
This failure can be located in the power supply. Open the receiver and look for part C21 and replace it. That should fix you receiver.
Using a de-soldering iron or de-solder ****** remove C21 (1000uF/6.3 volts).
Replace C21 using the same capacitance of 1000uF/6.3 volts or a higher voltage is acceptable if the part does not interfere with the adjacent capacitors. 1000Uf/35 volts should fit in there as well.
Good Luck.
Apr 29, 2008 | Televison & Video
Coolsat 7000 pvr
You could check for further info for this model through the following site:
http://forums.f2atv.com/
Oct 27, 2007 | Computers & Internet
Buttons not working
Have you checked whether the front panel of your reciever hinges down or up if it does there may be a cut off button under there which when operated will let the front panel buttons work again
Dec 21, 2017 | Denon AVR-1601 Receiver
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
