Question about Maytag MSD2656G Side by Side Refrigerator
Maytag side by side not cooling
The whole fridge was warming when we got up this morning, so we transfered everything to coolers, and the freezer started cooling on it's own about two hours later, but the fridge side is still warm. The small flap in the back near the bottom behind the drawers is covered in frost, and no ice is being made. Can you help me?the coils freeze over and the refrigirator gets warm due to the restricted air flow. I took it apart and manually defrosted it also checked the circuit for the heater wire it was ok I then changed the module. It still does the same.
    President:
  • 1,214 Answers
Sounds like the defrost circuit has failed. It could be one or more of the following -
Adaptive defrost control
Defrost heater
Defrost thermostat
Reply back if you have troubleshooting skills and I will help more.
Posted on Feb 01, 2009
  • Maytag Master
  • 19,396 Answers
That means that the evaporation system is not working.
Do a complete defrost overnight, if you keep having the problem, check defrost system and thermostat, if they are ok, you may need to replace compressor/recharge gas.
My fridge side is not cooling,but my freezer is freezing
seems like you have a defrost issue, with this unit, its more than likely the adaptive defrost control found in the upper right hand corner of the fridge. You have to take down the lights and control....
You can find your part on any of the Parts websites for around 75.00..
IMPERITIVE unplug the fridge before replacing the board..
Aug 01, 2012 | Maytag MSD2756G Side by Side Refrigerator
I have a GE SxS that sounds like it is running all the time. The freezer appears to be fine, but the fridge is not cooling like usual. In fact, we have change the temp settings to make it cooler and even...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My maytag side by side is not cooling right.when the weather gets hot and humid the freezer won't freeze anything and the fridge isn't cold enough.when the weather is cooler everything works fine. it is an...
Clean the condenser coils underneath the fridge.
Check condenser fan at bottom of back of ref.
that its not slowed or stopped
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | Refrigerators
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Fridge warm, freezer fridge temp
The adaptive derost control has gone bad a very common issue. It will work a couple of weeks before its back to its frosting over. It just plugs in but to get to it you must remove the controls at top of frigde section in the back right corner held in by two scewrs.
Mar 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Hello Hellohiester,
Defrost circuit failure:
The FROST I the back means you are suffering
DEFROST FAILURE...
There are only 3 basic elements:
- Defrost thermostat (prevents overheating)
- Defrost Heat element (raises temperature (mildly))
- Defrost PC board (starts DF cycles) 61005988
http://www.appliancepartspros.com/search.aspx?model=msd2656g
Very simple & easy to fix ($72)... (see video)
With YOUR model number... check out (6 minute)
online VIDEO instructional directions...
http://www.appliancepartspros.com/whirlpool-defrost-control-board-61005988-video
My favorite website at appliance parts
Thermostat & HEATER assembly ($50... see VIDEO)
Whirlpool WP61006198 Defrost Assy AppliancePartsPros com
Sometime BEST prices (SEARS: I don't personally care for)
sears Water Filters Lawn Garden Appliance Parts
Hope this helps
Carnac the Magnificent
Nov 24, 2017 | Maytag MSD2656G Side by Side Refrigerator
Fridge side by side and freezer not cooling
The fridge is working again and I don't understand why. Thanks anyway all is good.
Jul 22, 2008 | Whirlpool GS6NBEXR Side by Side...
GE Profile- Freezer/ Fridge at 56 wont go cooler!
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Maytag MSD2656G Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
