Toshiba TP55H60 - High Power Board
Neighbor got new TV, gave me his old one. Son and I were looking for an electronics  repair project, and this found us. Neighbor said this one needs high power board, otherwise fine. Very good condition overall.
Any suggestions on where to find? Checked ebay, nothing listed for this model number.
Thanks.
  • evansdave Feb 02, 2009
    I'm not sure what you meant by  "check the manufacturer" )Toshiba) so here is what I;ve done:
    1) Visited Toshiba site -- no parts available (at least not that I found);
    2) Visited eBay -- did not find boards listed for this model (may be looking in wrong place.)
    Can you clarify what you meant?  Would definitely appreciate URLs or simialr direct pointers to actual solutions.
    Thanks-
    D
    Sergeant:
    Champion:
  • 346 Answers
Check the manufacturer
Posted on Feb 02, 2009
My 55 Toshiba rear projection Will come on, then turn itself off in just about 5-10 seconds. Sometimes I notice the power button is flashing after. What is wrong with it?
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck.....
Oct 07, 2010 | Toshiba TP55H60 55" Rear Projection...
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
The power lamp flashes when turned on, no picture???
Ur tv needed a new lamp.Ur current tv lamp,in the tv now.U used the tv about 4 or 5 hours a day.Like the last 1 1/2 or 2 years the tv in used?The lamp life span is over.
May 14, 2010 | Toshiba TP55H60 55" Rear Projection...
Fuzzy picture and dark picture and color seperation when hot.
The colors seperating is a convergence problem, as far as being dim this may be related but the TV likely needs service adjustments.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Toshiba TP55H60 55" Rear Projection...
I have a toshiba tp55h60, power light is flashing
I have the parts you need if interested. Email me at hill6399 at yahoo.
Oct 30, 2009 | Toshiba TP55H60 55" Rear Projection...
Convergence problems TOSHIBA TP55H60
you need to replace the convergence ic's these are the stk-xxx-xxx chips found on heat-sinks
on or around the main chassis don't adjust the tubes or anything else this will only make things worse after you replace them you can do the user alignment also check the values of the resistors in the circuit as they may be off now pay close attention to the resistors that have a value less than 10 ohms these are critical to the correct alignment if in doubt replace the resistor.
Jan 02, 2009 | Televison & Video
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
