Question about Vizio P42HD Television
New vizio 42" is posterizing
Dark colors like black are sprinkled with red sparkles which i guess is posterization. its a new tv whats causing this?
  • finnertyxpre Feb 18, 2009
    We actually took the tv back to store and got a better one with higher megahertz. We like it a lot better. Same brand though!
    New Friend:
  • 56 Answers
I think it cause by vs voltage is high. You can try to decrease the Vs voltage a little bit. You can adjust the voltage while the TV is on. The Vs voltage adjustment is locate in the power supply.
Posted on Feb 18, 2009
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
What's the perfect combination to decor the room?
Room posters alone may not be very much entertaining as much as decorated rooms add life your overall environment. But, interior designers think that the perfect combination of an awesomely arranged interior design is to make a perfect combination of decorated rooms and posters. Visualize! How things seem to be in the presence of only a room poster. Moreover, if a room is decorated, without having a poster on its walls, it would give an incomplete look. Therefore, the best part would be to make a combination of decorated rooms and room posters. For instance, if you are having a red-colored entirely decorated room with a perfect combination of a poster on all its walls, what a beautiful look it would give to you and your guests. So, what you have to do is to go for artistic room pictures or Wall posters in order to decorate your rooms in a perfect way.
Sep 20, 2015 | Canon PosterArtist 2008
Vizio lcd tv red and black
A thorough check should be done to your set. It sounds that the panel is faulty. Check this link for more details.
Sep 22, 2012 | Vizio 42 in. LCD TV
42" philips plasma, black screen and flashing red light
This fix was posted on similar problem, worthy of repeating: Replaced 3300mf 10V capacitors at PS. Both had bulged slightly. Upsized to 25V as the previous solution poster had suggested 16V but I could not locate 16V so used 25V and TV is back to normal!
Nov 29, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 42"LCD Red Dots when warm
sometimes changing from hdmi to composite inputs solves it.
Jan 01, 2018 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio 42" P42HDTV10A Picture very faded
It sound like you have a dark display. Replace Z Sustainer board will fix it.
Feb 15, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Sparkles
Makes you wonder why nobody is taking on the problem, doesn't it?
Well , to the best of my knowledge, it is because nobody really can.
To understand why you have to understand what do they sparkles come from.
They are random electricity discharges coming from capacitors or other components that act like capacitors, but mostly capacitors.
When laymen hear about capacitors they usually associate the word with bulged electrolytic capacitors, which often cause problems in electronics of all kind.
Well this time it isn't about them.
It's about all other capacitors - or other components exposing similar qualities - which are installed on the board. Most of them are small filter capacitors put in parallel to the big ones or to other passive components such as diodes and resistors.
The excessive heat developed by the sustain boards damages those capacitors. It hardens the electrostatic material they are made of and small breaks in it start occurring at voltages that shouldn't otherwise be causing issues.
The trouble is, they can be everywhere. You can't just pinpoint which ones were caught at fault and causing the sparkles.
When it gets REALLY bad eventually the whole capacitor burns and either shorts or, more commonly, just breaks.
Believe it or not I've seen a board that exploded before my very eyes and , after the explosion, started working LIKE A CHARM!
Turned out a small filter capacitor had blown. It as not essential for the board's functionality and after being problematic for so long and causing image deffects it had eventually shorted completely and literally exploded.
Luckily, the short it had created was too short in time and apparently in a circuit that could take the load for a short while without getting damaged.
So after it blew everything worked just great!
it's a real story from my repair experience.
Hope this helps all consumers, DIY enthusiasts and competitors alike :-)
For more you are welcome to visit our site and read our tech repair blog at
http://www.coppelltvrepair.com
and
http://blog.coppelltvrepair.com .
Aug 26, 2007 | LG 42PX5D 42 in. Plasma HDTV
Vizio P42HD Television Logo
625 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
