Question about Roper RAS8445KQ Top Load Washer
Roper washer will not spin
Washer will not spin but water pumps out of it. my husband already checked everything underneath and it is all working fine. Please help!!
  • 135 Answers
Check the coupling between the motor and gearcase carefully. If it is good, you'll nees to replace the gearcase. Hope this helps!
Posted on Feb 16, 2009
My Roper washer will only work on the spin cycle. It will not fill or work on any other setting. The fill hoses are clear of debris and there is no kink in the drain hose. What do I check next?
The indication you state is consistant with the washer sensing water in the tub. If there is no water in the tub, then it would be the tub sensor. If there is water in the tub, and the spin cycle doesn't get it out, then I would look at the pump or the control board.
Jun 08, 2011 | Roper Washing Machines
WASHER WONT DRAIN
Does the washer spin on rinse and drain cycles ok? If it does spin but won't drain, the problem is the plasic impeller in your drain pump. This model is a direct drive unit with a reversing motor that runs one direction for agitate, but reverses to spin the tub and operate the drain pump. So if it spins but DOES NOT drain, it's the drain pump, but if it doesn't spin or drain, than it's probably a lid switch. Also the tub to pump hose or pump discharge hoses may be clogged with something. If your mechanically apt, you can do this repair yourself and save a service charge. The pump runs about 30 dollars or so and is really easy to change out. Check out Youtube videos on Whirlpool washer repairs, they will show you everything to do. Yes, I said Whirlpool, because Roper is built by Whirlpool.
Hope this helps
kcomp1863
Dec 29, 2010 | Roper RAS6233KQ Top Load Washer
Water will not drain, does not spin. It's not the timer, changed it already. I believe it is the agitator clutch?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 28, 2010 | Roper RAS6233KQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Roper top loader direct drive washing machine vibration on spin
the counter weights inside gone bad or u need to balance the machine legs , use a leveler to check balance
Nov 12, 2008 | Roper RAS6233KQ Top Load Washer
Waher
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
99 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
