-   Where is the master reset button at on the G1 I have a bluelight flashing the screen will not come on need help? -   Neef247
Mar 22, 2009
-   Have the same problem-   Guest
Feb 09, 2009
-   Same exact problem here. Blue light then after taking the battery out and putting it back in, flashing red light. My son read somewhere that the menu button and the mouse button were apparently both pushed dn at the same time for a short period of time causing it to lock up. Still looking for a solution to this issue though. -   krparkerone
Feb 06, 2009
-   same thing happened to me, the battery still seemed ok, since the icon still showed a fully charged battery. it just shut down out of the blue, and when i try to turn it back on, it flashes a red light at the top side. -   hishamhamad
well plug the charger into the phone with the battery still intact.....then remove the battery while the phone is still plugged in. then unplug the charger and plug it back in........place battery back into phone and then power it up. That worked for me.
If you turn the phone on whilst holding the trackball down, then the blue light will come on and the screen remain dark. If this is happening all the time I assume the button is wedged down or wet causing it to short.
HAVE A G1 and my daugthter slobbered on it and after a while only the blue light shows with no screen. Can anyone help me before i decide to buy a new one? Get at me quick.
At this point you would want to use a different outlet, try and different charger, or replace the battery. If it is still not powering on you would want to attempt a master reset to the device.
i dont have signal anywhere either and i tried to do the solution you have here and that doesnt...
(More)
i dont have signal anywhere either and i tried to do the solution you have here and that doesnt work.
when i leve face book or close the phone or open the phone tell me ,process android acore stop...
(More)
when i leve face book or close the phone or open the phone tell me ,process android acore stop unexplicable tri again
