Question about HP Pavilion 753n (P9852AR#ABA) PC Desktop
On my HP Pavilion I set the BIOS to change the boot order from the CD drive first. Then I intalled Fedora 9 and when I tried to reboot the machine will not boot. I have tried booting with the Win XP cd in the drive and with the Fedora DVD in the DVD drive. I have diconnected the power from the drive and tried booting from each. I get the same result: power comes on but no boot activity. The lights on the keyboard blink, the drives make a little noise and then nothing.
    Sergeant:
    Champion:
  • 275 Answers
Try resetting all the connections and also disconnect the power cable from the back of the computer and hold down the button for 10 seconds and start the system that should work
Posted on Feb 01, 2009
Hp Pavilion doesn't read CD/DVDs while in OS; WinVISTA.. Solution?
You need to go Bios setup and then reset the boot option, choose first boot as CD/DVD and then save settings and reboot now. Your issue have been resolved.
Good Luck
Aug 14, 2012 | HP Pavilion Computers & Internet
Boot hp pavillon zd8000 with usb not possible?
Boot hp pavillon zd8000 with usb is possible.simply plug the USB flash drive with iso and reboot, then press F10 navigeyt Boot Order Mark hard drive, hit enter, Highlight your usb and press F6 so usb was on top of the press F10
May 15, 2012 | HP Pavilion zd8000 Notebook
Hello my Hp Pavilion dv5215us is having some problems. When I turn it on it says PXE and something about LAN. so I checked online and I was told to change the Boot Order but im not sure how to do that...
F1 or F2 key to access bios. Then go into the tab that says boot order and set the boot devices as:
1.) Optical drive
2.) HDD
3.) whatever is left
If you are getting the PXE message though, it indicates that the laptop is not finding a boot record. You need to check if there is a working hard drive fitted, whether it needs windows re-installing (or repairing) and whether it is even appearing in the bios as a device.
If it is , you should try to install windows from the CD disc, if the boot order is set to CD first, it will prompt you to press a key to boot from CD, after that (and if windows was installed on the hard drive) run it till it finds the previous installation of the OS and repair it via the installation cd
Jul 22, 2011 | HP Pavilion dv5215us Notebook
Hp pavilion a530n will not boot for cd it says not hard drive found reboot and select proper boot device or insert boot media in selected boot device
Need to set it to boot onthe CD drive.To boot on CD drive;
1-at start up press F2
2-At BIOS select BOOT option and move the CD drive to the fist option using the keyboard arrows.F10 to save and exit.
Oct 26, 2010 | HP Pavilion A530n (DW234A#ABA) PC Desktop
I Have an old HP pavillion model N3410. I am trying to access BIOS or change boot order but it won't let me. I've tried pressing f2 during reboot but it goes straight to normal windows me startup.Also...
Turn the computer off.
Hold down any key on the keyboard, and turn the computer on.
You might get a "keyboard error, press <something> to enter BIOS SETUP".
Also, instead of F2, try F1 or F10 or F11 or F12 or DEL.
Aug 20, 2010 | HP Pavilion N3410 Notebook
My hp pavilion zd7000 wont boot up, how do I get it to turn on. Had some kind of Java virus was trying to reboot computer, and now it won't turn on at all. Computer illiterate here almost.
hi
becoz of virus you have re install your OS
you have boot from Windows CD just put into ROM then restart your computer it will boot from the CD if not then you have go in bios and change boot option
Aug 04, 2010 | HP 336084-6C0 - HP Pavilion zd7000...
I am presently using fedora12.now i want to install windows 7 is it possible,they cannot taken any booting from the cd,by default grub installer is loading
Hi Thanks for your question
In order to boot from the CD drive you must change the Boot Order in BIOS.
In order access BIOS you must press certain key on the keyboard during start up. Depending on the machine it may be F1, F2, F3, F10 or Delete key. Once you acces BIOS you must find Boot order settings. Again depending on machine this may look different, but most of the time it's a separate Tab or settings may be in general part in BIOS setup. When you find it you have to place CD/DVD drive on the top of the list of Boot Order and before exiting BIOS sace changes. Now your machine should Boot up form CD and you should be able to install Windows 7. Do not hesitate to ask more questions if further assistance is needed. Good Luck
May 08, 2010 | fedora Linux Operating System
I have a s3100n hp slim line pavillion and thru hp tech support was advised to do a system recovery. when i tryed to reboot my system some programs were missing and they hp said that i need the recovery...
You must go into the BIOS on boot up and choose to boot from CD-Rom instead of the hard drive. When you first turn on your machine and the HP comes up push F10 key to get into the BIOS. Look for boot priorities and put the CD/DVD Rom in the first boot position (directions on how to move these item up/down are at the bottom of the page)
Then your disks will be useful. Put one in and reboot. It should read you disc and follow instructions from there.
Hope this helps you, good luck
Apr 23, 2009 | HP Hewlett Packard Pavilion Slimline...
New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Feb 01, 2009 | HP Pavilion zd7000 Notebook
HP PAVILION a305w
try getting into the bios and setting it to boot normally, turn off fast booting if its an option thats on, also, set your CD drive as the first boot devioce, then hard drive. Save and reboot, have CD in drive and just start hitting the F10 key as soon as it starts up, usually you hear a Beep when it detects that you are hitting the key for the boot options. HP pavilions where made to start and skip through the Post Process quickly to limit waitnig time, of course this sux when you want to boot from a cd.
You could try remove ing the BIOS Battery off the board and unplugging the system, wait a minute for it to discharge and put it back in, power it up and see if it lets you boot from CD.
Your bassically resetting the BIOS to factory defaults.
Also, i dont recomend buying HP Pavilions. i wokred on three seperate ones that a customer thought was a New machine ( this was back in 2001 ) but all the parts where 1995 parts, which means wghen they tried to upgrade to windows XP, XP doesnt have any generic drivers for hardware that old so nothing worked and yuo cant find any driver online that are that old.
Good luck anyway.
Feb 15, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP Pavilion 753n (P9852AR#ABA) PC Desktop Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
