Question about HP Pavilion a320n PC Desktop
USB device error
Error indicating the device could not be installed due to lack of system resources
    Sergeant:
    Champion:
  • 275 Answers
See if u are facing the same issue with all the ports ... if not try to connect someother device in the same port .. of which u know its working perfect ... and than go to start > right click on my computer > properties > hardware > device manager > and uninstall all the usb root hub and restart the system ... all devices will be re-detected ... and than try connecting the device again .. that should work ... if that doesnt u have issue with the motherboard
Posted on Feb 01, 2009
Epson error message 0x10
In the Properties toolbar of the device, access the Resources tab and select the device s resource and allocate it. When the resource chosen cannot be modified, access the Change in Settings and attempt to clear the Automatic Setting toolbar.Still having Problem Then follow Us For Epson Printer Support
Feb 16, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
Tip
How to fix blackberry phone errors by Updating the Firmware?
Most Blackberry phones encounter errors due to phone software failure.
Here are some problems and as this definition shown below.
JVM stands for JAVA VIRUAL MACHINE
* JVM Error 501: During memory management, freeing of resources from memory failed as a result of possible corruption
* JVM Error 517: The BlackBerry Device Software encountered unexpected data in a memory location which is used for normal operations
* JVM Error 535: Interaction with the file system has experienced a catastrophic failure
* JVM Error 547: While writing data to the file system, a failure was detected
* JVM Error 548: While erasing data from the file system, a failure was detected
Some can be fix by Hard reset,but most phone need to flash the frimware to be recover.
Here are the step by step procedure on how to fix your phone by updating the Firmware.
* You need a good working USB cable
* Battery is Fully charged.
1. Download Blackberry Desktop Manager and install it. : HERE
2. Download Flasher blackberry Tool : HERE
3. download & install flash file : CLICK ME
4. Delete the vendor.xml file located in c:program filescommon filesesearch in motionapploader
Open flasher blackberry Tool shown on this illustration
5. Go Next
6. You can see usb pin number if your phone is connected to your computer. go next
7. This is very important, don't forget check the box all apps you need and Go next.
8. Wait the application loader flashing in progress ...
9. you're almost there and wait when update is successfull ...
Done....
I hope this method simple helps you.
on Jul 14, 2011 | Cell Phones
Tip
Start up error
Some users have gotten an error message similar to the following when attempting either to shutdown or restart Win XP:
STOP 0000009F, DRIVER_POWER_STATE_FAILURE
STOP 0x0000001E: KMODE_EXCEPTION_NOT_HANDLED
STOP 0x000000D1: DRIVER_IRQL_NOT_LESS_OR_EQUAL
TechNet and the Microsoft Knowledge Base have numerous articles discussing this type of error condition; for example, these. As a review of these articles will show, these are commonly device driver problems, but may also be caused by troublesome software (such as the notorious CrashGuard), or a problem in a system service. MSKB article Q262575 discusses a shutdown problem of this type, known to exist in Windows 2000 due to a resource (IRQ) conflict, if you have PACE Interlok anti-piracy software installed. This problem may occur in Windows XP as well.
Microsoft advises the following as one approach to these problems: Restart the computer. Press F8 during the restart and select “Last Known Good Configuration.” If you catch the problem when it first occurs (meaning you likely have installed only one or two drivers or new service), this will return you to a previous working condition. (Would System Restore accomplish the same thing? I don’t know, and don’t have a broken system to test it on.)
Microsoft reported similarly that these STOP code error message occur when Windows XP is trying to shut down devices. He says that he has seen this twice: once with Logitech Quickcam installed (with an unsupported driver), and once with a USB DSL modem that would hang if it wasn’t disconnected before shutdown.
on Jan 01, 2010 | Computers & Internet
Wi fi not working error 10
Code ten means there was some kind of hardware error that prevents windows from loading the driver.
If it is a USB Wireless device, make sure you are not using a hub. Plug it into a full power USB port.
Try a different port. If it is a built in card, such as PCI or MPCI-E, you will likely need to replace the device. Sometimes you can get a code ten from lack of resources. Try dissabling some hardware you do not need in the device manager. Items such as serial ports etc. (Anything you don't use)
Mar 25, 2011 | Computers & Internet
I have SandDisk S3 UCL Mode USB Device which is not detecting right now. One week back its working fine. In computer management i found device has in diabled mode. when i try to make it enable its again...
How to Fix a Code 22 Error
  1. Enable the device. Since the most common reason you'll see a Code 22 error in Device Manager is because the device has been manually disabled, try manually enabling it.
    Most of the time this will fix a Code 22 issue. Don't worry if it doesn't, however. All that means is that the Code 22 you're seeing was caused by something a bit less common.
  1. Restart your computer if you haven't already.
    There's always the chance that the error Code 22 you're seeing on a device was caused by a temporary problem with the hardware. If so, a restart of your computer might be all you need to fix the Code 22 error.
  2. Did you install a device or make a change in Device Manager just before the Code 22 error appeared? If so, it's highly likely that the change you made caused the Code 22 error.
    Undo the change if you can, restart your PC, and then check again for the Code 22 error.
    Depending on the changes you made, some solutions might include:
  1. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is one possible solution to a Code 22 error.
    Important: If a USB device is generating the Code 22 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Correctly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
  2. Update the drivers for the device. It's also possible that installing the latest drivers for the device could correct the Code 22 error.
    If updating the drivers does remove the Code 22 error, it means that the stored Windows drivers you reinstalled in the previous step were either damaged or were the wrong drivers.
  3. Clear CMOS. If Windows had to disable the device, generating the Code 22 error due to a lack of system resources, clearing CMOS might fix the problem.
  4. Update BIOS. Another possibility is that a newer BIOS version could better pass system resource handling to Windows, correcting the Code 22 error.
  1. Move the device to a different expansion slot on the motherboard, assuming of course that the piece of hardware with the Code 22 error is an expansion card of some kind.
    If the Code 22 error is due to a lack of system resources available for the card, moving it to a different slot on the motherboard could clear up the problem. This isn't as common a situation with newer hardware and Windows versions but it is possible and is an easy troubleshooting step to try.
  2. Replace the hardware. A problem with the device itself might be the root cause of the Code 22 error, in which case replacing the hardware is the next logical step.
    While not likely, another possibility is that the device is incompatible with your version of Windows. You can always check the Windows HCL to be sure.
    Note: If you're positive that the hardware is working properly and is properly configured then you might consider a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either before you replace the hardware, but you may have to give them a try if you're out of other options.
Please let me know if you've fixed a Code 22 error in a way I haven't mentioned above. I'd like to keep this page as accurate as possible.
What Does the Code 22 Error Apply to?
The Code 22 error could apply to any hardware device managed by Device Manager.
Any of Microsoft's operating systems could experience a Code 22 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 22 Issues in Device Manager?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more.
Be sure to let me know that the exact error you're receiving is the Code 22 error in Device Manager. Also, please let us know what steps you've already taken to try to fix the problem.
Show Full Article
Aug 03, 2017 | Computers & Internet
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
I am trying to use a UDB Flash drive. I get a message that indicates that an error occurred during installation of the device - Insufficient system resources exist to complete the requested service.
ur system is not support the device may be the processor or ram are motherboard support so can u check the system is support for the device.some time it may be operating system also not support.
Feb 01, 2009 | HP Pavilion a320n PC Desktop
Destop cd driver
is this an external USB CD Drive ?
Windows error code 10 indicates a hardware error or failed driver installation. This error may appear if a device has insufficient power to operate correctly (if it,s plugged into a bus powered hub with other devices), or may indicate a more serious hardware problem. Also, it may be indicative of USB root hub drivers being incorrectly installed.
This could be a faulty or dirty USB Lead problem.
Hope this helps.
Mike @ Compurepair.
Feb 22, 2008 | Microsoft Windows Vista Ultimate Edition
HP Pavilion a320n PC Desktop Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
