Philips pet700 disc does not spin and screen says no disc
Screen shows loading then no disc. The laser moves but the disc does not spin -- managed to get it to spin by manually pushing it to start, but it stopped after a few seconds though it did try to spinup for a short time.
  • l15sty Apr 26, 2009
    philips pet700 disc does not spin and screen says no disc
5 Suggested Answers
SOURCE: DVD stopped playing all DVDs
solved. just clean the lens with lens cleaner
Posted on Feb 21, 2008
  • 814 Answers
SOURCE: Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Posted on Jun 09, 2009
  • 188 Answers
SOURCE: The player is not recognizing there is a disc in
Faulty laser unit or the power supply is to low due to bad caps.
Posted on Aug 23, 2009
xptareq2000
  • 1447 Answers
SOURCE: My philips PET700 portable dvd player will not play any discs.
No it is not expensive.You go to a workshop they replace Laser .May be coast 7 USD
its problem on laser unite.
Posted on Jan 12, 2010
Philips DVP Playing problem
try to clean or change the laser
Mar 11, 2010 | Philips DVP642 DVD Player
Dvd player not reading new DVD
probably needs a new belt they do wear out and loosen up over time
Feb 16, 2010 | Philips DVP1013/37 DVD Player
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Durabrand DVD Model 1002 Want load disc
The laser or pickup has failed or is out of alignment. That symptom is caused by either a dead motor, or a bad laser. The only thing you can MAYBE check is that there is no dirt or grease on the lens. If it is clean it is time for a new unit.
Cheers
Jan 30, 2009 | Durabrand Televison & Video
Sony PlayStation 2 - Does not read CD
IT IS THE EYE. the eye th the little shiny piece that you can bairly see once the tray comes out.you might have put a disk in at a wrong position and scratched the eye. replacing it might be what to do, but i would check first.
Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
Suspect the optical pick up, may be cheaper to buy a new unit!
May 29, 2008 | Akai LCT3201TD 32 in. LCD Television
No Disc
It could be some dirt & dust on laser lens. Did you try to clean it?
Oct 10, 2007 | Philips HTS3450 System
I put a disk in and it just keeps loading...
Have you dropped your player? I dropped mine and I am experiencing the same problems. I'm trying to find information on how to fix it.
Apr 29, 2007 | Philips PET710 Portable DVD Player
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
