Question about GE Ovens
GE Model #JBP76GS1WW Oven Control Knob
Knob sheared off. Plastic shaft broke in half. Half of the shaft is in the knob, the other half is imbeded in the rheostat temperature control assembly which is factory soldered to the circuit board. The only thing I can think to do short of buying a new $350 Control Assembly is to drill a centered hole in each part of the shaft and epoxy the shank of a machine screw into each end of the sheared shaft efectively joining them back together.
The only other thought is to drill out the broken shaft from the temp control assembly and attempt to replace it with a stell shaft of one sort or another. In looking at the rheostat of the temperature control assembly, I'm unsure how the shaft end joins and manipulates the rheostat inside.
Any thoughts?
First contact GE directly, they will send you replacements for half that price and you can do the labor yourself. 1-877-959-8688
Posted on Feb 01, 2009
Where can I get a replacement "Oven Function Selector Switch" for a BOSCH OVEN - Model No. HBE632UAU/03 (Year of Manufacture 1991) Part No. 05 5870 which was later replaced by Part No. 05 9863. The...
try going to goole.com and put in appliance parts there will be a number of sites that will come up many in the USA that have many parts.
May 16, 2014 | Ovens
How to replace selector switch on a belling country chef,the switch is ok but the shaft to the knob has broken
I have a country chef half gas and half electric ,the shaft has broken of half of it is in the control panel and other half is in the knob. How do I get a new shalf and how do I put it back on ,I would be very grateful for your help please message me.
Apr 30, 2014 | Belling Ovens
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Creda Oven Model ESO 210 broken multifunction selector knob
Same thing happened with my Creda ESO 210. The function selector works find. It just doesn't rotate the piece of plastic that has the funtion symbols on it. I contacted the authorised parts supplier in Canada and was told it would cost $90 for the part. After a long wait, the part arrived and it wasn't the correct piece (they'd ordered the little plastic circle with the function symbols on it instead of the knob thingee that moves it). So, if that cost $90, I dread to think what the broken mechanism would cost. So, I gave up and I simply count the clicks from the off position to use my oven. However, if you really want to follow up on this, you can contact www.creda.co.uk.
Jan 20, 2010 | Creda Europa E010E Electric Single Oven
Hi..if i set the control knob to 350 for the oven..its goes to 400 or 450 degress..i put a oven termonater in there..its always hotter than what u set it on. model # JBP24G0K2AD or the o is a 0 not sure..
The oven thermostst needs replacing, as it is not sensing the correct temperature, this is the switch behind the control knob
Please rate my solution.
Thanks.
Nov 10, 2009 | GE Ovens
Fan control knob sheared off w/ part of stem... can i replace,if so which parts tks, mgw
You need to replace both the control knob and the switch it is located on.
Thanks.
Jul 16, 2009 | Jenn-Air JJW8530C Expressions Collection...
BOTTOM OVEN WIILL NOT HEAT
check the bottom heat element and see if you see any burn out spots on it,if so you will have to replace it(easy)let me now-mike
Oct 13, 2008 | GE JKP28 Electric Double Oven
Old GE wal mounted oven Model J55BE-1
I have the same problem. Did you ever find the solution
Oct 05, 2008 | GE Ovens
Ovens Logo
321 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
