Kenmore front washer 44052401 all green lights blinking
I tried the pressing select and options for 5 seconds to reset, tried unplugging it. and the problem is still there. The machine is 3 years old.
  • Ineedafix99 May 16, 2009
    i had same problem..all green lights.except for the door locked will not light i just pressed select and options for bout 20 seconds and it resolved the issue.
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
3 Reset System
From the remote, press
<MENU> <1-2-3>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
All customer settings are
reset to factory default.
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
I have a mitsubishi model WS-55511. The green light keeps blinking. Have reset by unpluging and then pluging back in and holding the reset but for 5 seconds and press the power button. worked once, but...
TWO possible reasons for the blinking light:
1. The DM unit (caps and or fuses) are bad---no longer made and only (to my knowledge) PTS electronics repairs/rebuilds them.
2. Less likely but Possible: remove front speaker grill and inspection plate behind it----locate the two bundles of wires from front keyboard on set and follow them down and to the right---unplug both plugs and plug set in and wait 70 plus seconds and try to turn set on with Mitsubishi remote.
The blinking light is the DM trying to boot up--if set works with front keyboard unplugged---the tiny reset switch on it is bad.
If set does NOT work that way DM UNIT IS BAD.
May 03, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The tv just turns off after about 5 seconds and won't stay on. i've used the system reset and unplugged it already. no power surge, lightning storm, etc. Ideas?
If reset does not cure it and if after about 70 seconds of unplugging set the green power light stops blinking, do this:
When power light comes on and goes off, on the front of the set press and hold both the menu and input buttons at the same time for at least 5 seconds and RELEASE both buttons.
Power light should blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it four more times.
Let me know what error code you find and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
Aug 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I have no power, i called a repair man, he said unplug it then push the reset button...i get a blinking green light for a few what?
The set if it has a DM unit when unplugged should blink for 70 seconds and allow you to turn on.
If it does not, if when you try to turn on green light comes on and goes off---do the self check:
Press and hold both the menu and input buttons for 5 seconds and release both; power light should blink a two digit error code at least 5 times. 2 blinks, pause and 2 blinks is the most common.
If the set has a reset button on the front it has a DM unit---built in receiver--even if it fails the green power light will blink nonstop.
Again, if you try to turn on and green power light comes on and then goes off---do the self check and let me know what you find.
If this information was helpful rate this solution as "very helpful" as I do this here for free.
Also let me know what you do or do not find as I am here to help you.
Aug 11, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Kenmore elite 3t the front light to select wash blinks but when s
Press 'drain' & 'spin' together for 3 seconds to see if it clears. This is your control panel lock.
If not cleared unplug the washer & wait for 30 minutes for the CCU (computer) to reset.
If helped you can rate.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite won't start
First of all, make sure haven't inadvertently locked your control panel. Press and hold the DRAIN/SPIN button for 3 seconds to see if it clears. How long did you unplug the washer for? The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Try this first and let me know what you have. It could be you only have a minor glitch.
If these preliminary checks prove unsuccessful, you may have a control panel problem. Do you have any error codes deisplayed? Please reply and let me know what you have.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Dec 26, 2007 | Washing Machines
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
I press the start button and it says error.
Had the same symptoms. Tried unplugging power for 5 minutes, no change. Did the Select+options button for 5 seconds, the column of lights flashed once, and then I hit the Start, the door locked, clean clothes followed shortly thereafter :)
Jun 12, 2006 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
