Question about Casio G-Shock GW300CA-1V Wrist Watch
Sportcraft Heart Rate Monitor Watch
How do you reset the time from 24 to 12 hour?
0434 and 02040328 are the only numbers on the casing.
the buttons are (from top left - watch face - clockwise):
Select
ST/FWD
Scan/Rev
Mode
On mine you press and hold the ST/FWD button.
Posted on Feb 17, 2009
Press the MODE button as if you are going into the mode for reading your heart rate.
Then press the upper right button, ST./FWD which will bring up a time indication on the top line and, in your case, a 12h below that. Continue to hold that button until the time changes to 24h.
You can then go back into the regular use of your watch.
Hope this helps.
Eric
Posted on Feb 27, 2009
How to unlock my heart rate monitor
Tap mode, it will bring up a screen with the date and time on it.then hold reset. The lock will start blinking and then disappear :) It looks like you guys are probably done with this watch but I thought I'd answer anyway. Good luck.
May 22, 2012 | Footcare New Balance Heart Fit Komen Heart...
Heart rate is off, how do you turn it back on.
Press and hold the reset button, for 5 seconds, while in Time mode. The heart monitor will reset and you should see the heart symbol appear.
Mar 30, 2011 | Sportline 915 Solo Heart Rate Watch
Under the settings, limits, the limits on the max HR stop @ 100. I want to increase the setting on max hr but it stops @ 100 and then returns to 18. help [polar F4]
Go into settings.
Press the center button on the right hand side of the watch 1 time you will see settings watch time & date appear in the display.
Press the bottom button on the right side of the watch1 time to get into the TRAINING SETTINGS FUNCTION.
When you see TRAINING SETTINGS in the display press the center button on the right side of the watch once.
You are in TRAINING SETTING mode.
Press the bottm button on the right hand side of the watch 3 times until you see
ZONE LIMITS displayed.
When you see ZONE LIMITS displayed press the center button on the right side of the watch 1 time to enter into the ZONE LIMITS FUNCTION.
Now, you should see the lower end heart rate limit number blinking.
To adjust this number use the top button on the right hand side of the watch to increase this limit or lower button on the right hand side to decrese it.
When you have it set where you want it press the center button 1 time to save that setting.
Now you should see the upper limit number blinking.
Follow the same steps to set the upper heart rate limit.
When you have pressed the ceter button to set the upper limit you have completed setting the heart rates limits and the display should read: LIMITS SET!
Feb 13, 2011 | Polar F4 Heart Rate Monitor Watch
How do I reset the chronograph? Once I start it I can't find a way to reset it.
In heart rate mode, click reset to go to Calorie burned mode. In that mode press and HOLD reset button and this should reset all lap,calorie data. etc
Jan 06, 2011 | Sportline 1010 Duo Heart Rate Monitor...
The heart rate function has turned off. So the calorie count won't work. Everything else is working fine. It happened about four days ago. I have lost my owners manual.
Press and hold the reset button, for 5 seconds, while in Time mode. this will reset the heart monitor and the symbol will reappear on the screen.
Nov 26, 2010 | Sportline 915 Solo Heart Rate Watch
How do i reset the Timex Zone Trainer Digital Heart Rate Monitor Watch T5J983 for each workout?
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Nov 18, 2010 | Timex T5J983 Zone Trainer Digital Heart...
How do you turn the heartrate monitor on?
How do I turn the Heart Rate function on and off on my watch? Within the Date and Time screen, if the heart icon is showing, the heart rate function is on. To turn off the heart rate function, simply hold the Reset button until the heart icon goes away.
Aug 14, 2010 | Sportline C9 by Champion Fitness 910 Watch
SPORTCRAFT Heart Rate monitor watch
Go to:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2016.pdf
Full user manual and instructions there to download.
Please contact again if this in not successful, if it is, your rating would be most appreciated.
Mike.
Feb 22, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
I have a mio euorfit heart monitor watch. During my workout I
Yes, you definetely need battery replacement.
As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
Find your nearest watch repair shop and ask for battery replacement.
Do not forget to rate, please.
Jan 23, 2009 | Mitac Mio Fit Heart Rate Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
1,222 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
