Question about Hotpoint WD62 Front Load Washer / Dryer
Aquarius wd62 front drawer leaks
At the start of a wash programme, liquids leaks from the front drawer, down the front of the washing machine and all over the floor.
Any ideas please?
  • Valerie72 Mar 08, 2009
    Hotpoint WD63 leaks from the drawer and down the front of the machine dosen't do it every time about 8 out of 10 washes.
I had this problem and solved it by just leaving the draw sticking out a little bit! Now there are no leaks!
Posted on May 22, 2009
At 20 minutes the drawer leaks
have you removed the drawer and cleaned the soap drawer holder ? as these can be blocked and cause this fault
Sep 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Where do i put washing powder in hotpoint aquarius 1000 three compartments in drawer what solutions go in what compartment
with experience, put powder in the first, softner in the middle second, pre wash in the third, but with that model i find its always best to use a liquid or gel direct into the machine, it makes the life of the machine last longer, also stops any build up residue
Jul 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint washing machine leaks at soap drawer
check for any in drawer. if not relevel unit. make front a little higher than rear
Jun 22, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Water coming out of the powder draw when the draw is closed
Hi
The hose from the drawer into the tub is blocked or kinked, not allowing the water down quickly enough
Feb 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd62
Try taking the top off, power off obviously!! and remove the draw unit, there is a pipe that runs from there to the drum.... I found a sock in mine that was the problem !!
Feb 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wd62 leaking from the drawer
Hi, check the electrict valve winding busted hot and cold.
Jan 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
WD62 drawer leak
remove drawer clean it make sure flap is free on drawer compartment
Nov 24, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machines is leaking from the front at the bottom
if the hoses & pump are not at fault, the water may be running down from the soap drawer inside the machine & dripping from above
Oct 21, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Water leaking (Aquarius 1200)
don't think using quick wash should make a difference as water intake is the same take drawer out and wash thoroughly especially the rinse compartment. if gunged up the water overflows the compartment and leaks down the front. otherwise, you may have a blockage in the hose from the drawer to the tub. take top off, remove this hose and clean disconnect from mains when you do this
Apr 01, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD62 Front Load Washer / Dryer Logo
199 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
