Question about GE Spacemaker JS966 Electric Kitchen Range
GE JS966 range door, glass is dirty inbetween inter and outer panes. Can I disassemble and clean?
  • kalamarca Apr 18, 2009
    I have the same problem. Glass needs to be cleaned inside the 2 glass panels.
TampaNative
  • 778 Answers
SOURCE: FOOD AND DUST BETWEEN THE GLASS
Hello MotoMom,
I have disassembled an insulated door with laminated glass to clean between the layers of glass once and will never do it again (as it took far too much effort and time).
I will suggest trying to get a fair flat rate (not hourly) for completing the task to your satisfaction, guaranteed for at least 1 year. I would also check with other appliance repair shops/technicians (other than just the GE authorized repair), unless it will void any warranty the oven may have.
I hope this helps you, and good luck.
Posted on Mar 18, 2008
aborcass
  • 2651 Answers
SOURCE: GE Profile range oven door
foil was just protective heat tape, there is a track across the bottom of door that is holding it up,
Posted on Mar 20, 2008
aborcass
  • 2651 Answers
SOURCE: Glass door GE JGS968
youlls need to remove the door forom the unit and disassemble the outer door glass, not a major deal, al ittle patience will get it done if oyou would like to know how to do it exaclty youll need to send me the model number so i can look it up for a part diagram..
Posted on Jan 16, 2009
MNTECH
  • 1543 Answers
SOURCE: GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Posted on Jul 01, 2009
  • 206 Answers
SOURCE: Replacing outer glass of oven door
This is glass because glass does not burn, does not melt at oven temperatures, and is a pretty good insulator. Also allows the cook to watch the cake rise.
I would not replace with anything but factor glass. Too dangerous, even regular glass is not properly treated to be safe in this environment.
The cash for clunkers gets extended to appliances soon, perhaps this makes a new one more affordable?
Posted on Aug 24, 2009
Clean the inside of an amana range door
well they do come apart if cleaning is desired look around the outer edge caution tho as the glass can fall out .
Mar 18, 2015 | Amana AER6011VAS
Broken outer door glass
Hi, I don't know where you live, I live in France and here you can simply go to a DIY store and they will cut you a piece of tempered glass to size. Not cheap but may be cheaper than going to the manufactures. I have replaced my woodburner fire glass and that gets alot hotter than your oven outer glass. Hope that is useful
Steve
Jan 06, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
After cleaning the inside of glass door is still dirty? What should I use to clean it?
you need to split the inner and outer door panels, then remove the inner glass pane from between the 2 sections then carefully replace all parts especially if its a self- clean oven type
Mar 05, 2011 | GE Kitchen Ranges
How do I replace the shattered glass in my GE oven door
No doubt this is a double paned glass panel. Two panes of glass with a divider strip separating the two for a "thermal break". Okay, you will need to remove the door from the hinges, and along the sides of the door, or possibly under the door gasket, you will find multiple screws that hold the two sandwiched halves of the door together. There should be a front panel, formed sheet steel, and an inner formed sheet steel panel which is coated with porcelin. When you have the front and back halves of the door separated, inside of one or maybe both of the panels you will find the clips, screws, or materials that hold this glass panel in place. Possibly it is in it's own frame, and the frame and glass both remove as one unit. Then it will be a matter of contacting Customer Service and Parts for your product, giving the Model #, Serial # and any other data that may be needed in order to replace the part with the correct one. Since this should be tempered glass, it will be quite heavy and at least 1/4" thick or so. The "thermal break" or space between the panes is so that heat does not transfer readily to the outside panel. Watch for any electrical connections for a door switch for the oven lamp, and be careful when removing the springs which allow the door to close and seal when in the closed position. And it might be helpful to take some photos of the disassembly process so that you can have a reference when you are ready to re-install the door. Be careful when removing the broken glass, and dispose of this carefully. Take your time, be patient, and don't force any thing, and you should be fine. Good lock. Kindest regards, Slats.
Sep 26, 2009 | GE Kitchen Ranges
How to clean the window on the door to my self cleaning oven?
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Aug 11, 2009 | KitchenAid KESC307 Electric Kitchen Range
I need to replace my outer glass door of my oven its an indesit i have all the parts but just can't get the old piece of glass off any ideas? please
You may have to disassemble the door to get to it. Are you sure this is not a double paned glass and it is 2 pieces of glass in one assembly?
Jan 29, 2009 | GE ZSC2001FSS Advantium Electric Single...
Jan 15, 2009 | GE Profile JGS968 Gas Kitchen Range
Hello MotoMom,
Mar 18, 2008 | GE JBP70SKSS Stainless Steel Electric...
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
GE Spacemaker JS966 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
