Question about Kenmore 63942 Dryer
Kenmore model # 96274800
Dryer will not come on at all but makes a click when u press start
  • Anonymous Feb 07, 2009
    i'm not sure of my model #. it's at least 10 years old. When pressing the start button, it buzzes but it won't start. THis happened before, but it just fixed itself. Now it won't. Unplugged it to see if that worked, but to no avail.
  • Kenmore Master
  • 8,220 Answers
Reach inside the dryer and try turning the drum. It shold be very easy to turn by hand. If it is stiff then that is an indication of a bad motor or rollers or Idler. Bust it down and take a look see. If you decide to get another motor remember the blower has reversed threads in it. So righty loosey on it.I can clean a dryer oil everything and replace the motor in less than an hour and that is throughly cleaning it too. Dryers are simple creatures. If you ain't got money for a new motor in these tough times you could try something drastic but it sometimes works. Drill some 1/8th inch oil ports in the bearing wells on either side of the motor. Carefull not to hit the shaft! Put some hi grade temp resistant zoomspout oil from ace hardwarer in each well and work the motor free.Use that same stuff to oil the rollers and idler. It may go 1 more load or it may last for years. Who knows? How do I get into my dryer and other good s stuff
Posted on Feb 07, 2009
My kenmore oasis dryer model #110.67062600 does not want to start when i pressthe start button
if the drum rolls freely, put your hand inside and pull the drum around, it is probably the timer
Aug 09, 2012 | Kenmore Dryers
Kenmore electric dryer model 110.60942990 wont start
the motor could be clogged up with lint take apart and vac out let me know if you need more help
Dec 12, 2011 | Dryers
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Dryer will not start
Forgot to check the thermal fuse. Now working after changing fuse.
Mar 21, 2009 | Kenmore Dryers
Dryer won't start when pushing the button it clicks
Could be a broken belt if you hear motor, also can be defective door switch. you can try pushing door switch with finger and press button If motor does not make a sound and pressing door switch does nothing you will need a volt meter and test for power if you hear moter then its broken belt or jambed drum. Try and manually move drum
Jan 14, 2009 | Kenmore 62602 Electric Dryer
Kenmore Electric Dryer 66812 clicking not starting
I hate to tell you this, but it is probably the timer. The good news is that it is easy to replace and you don't have to have a tech to do it.
Jan 05, 2009 | Kenmore 659 Electric Dryer
Kenmore gas dryer won't start.
Hi!!1 You have a shorted thermal fuze on the dryer..The thermal fuze is located in the back of the dryer its white and oval with 2 wire leads..replace it and you should be fine..good luck..
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Kenmore 63942 Dryer Logo
138 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
