Question about Zanussi ZBF360X Electric Single Oven
Zanussi Oven Door Shattered
Hi Guys,  I have a Zanussi electric oven.  The outer glass has shattered, my tenants tell me it happened on its own!  Suspect if you ask me, oven is two years old bought from new.  Anyhow, I am looking to replace it.
The model Number is : 949712286 / ZOB160W
I have looked on partsmaster.com but couldnt find the part.  Any advise would be appreciated.
Cheers
Krazytech
  • 725 Answers
SOURCE: Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Posted on Sep 29, 2008
  • 41 Answers
SOURCE: TKC 8522/2 top oven outer door shattering
the glass would only shatter if it was installed backwards but then it would of shattered a long time ago it shattered due to a scratch on the glass or the door was damaged
Posted on Jan 01, 2009
  • 4 Answers
SOURCE: kitchen aid oven door glass shattered
gget a new door
Posted on Jun 21, 2009
barkencoa
  • 3463 Answers
SOURCE: The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Posted on Jan 24, 2010
barkencoa
  • 3463 Answers
SOURCE: the outer glass on my hotpoint oven door has
You must replace it with the glass as supplied by the manufacturer, as it is is special heat tempered glass.
Posted on Nov 11, 2010
Oven door glass shattered
Replacement is likely not to be easy or cheap, but necessary.
Jan 10, 2014 | Tecnik Ovens
My outer glass shattered on lower oven
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Dec 11, 2010 | Ovens
Jan 24, 2010 | Zanussi Ovens
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
Main oven door outer glass panel shattered
I doubt you will get it cheaper any where, Zanussi is a bit of a closed shop.
If you can let me have the exact model no and the er number, I might be able to help you.
As for the reason it shattered, there are numerous reasons for this to happen, too many to go into, but it is a very common problem with cookers..
They do just go without any warning.
A cold kitchen could indeed be a factor, a badly fitting door is another factor, i could go on and on and on!!!!!
There is no one thing it can be put down to.
Plz let let me have the details I ask, and I will see what I can come up with.
Dec 12, 2008 | Ovens
Sep 28, 2008 | Ovens
Outer glass plate
glass was not tempered correctly contact the manufacture or possibly industrial glass products in ambridge pa they make them
Dec 14, 2007 | Miele H326-3 B Electric Single Oven
Outer Glass Microwave window shattered after baking popcorn
doubt anything to do with popcorn. glass like that does sometimes shatter probably a stress fracture. quite often happens with oven doors as well
Apr 19, 2007 | KitchenAid KEHC379JSS Electric Double Oven
Zanussi ZBF360X Electric Single Oven Logo
321 people viewed this question
Top Zanussi Ovens Experts
ashburton
marley mcelhinney
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
