Question about Home
The air intake control on my Eljer, Model 112-1800, bathub badly tarnished and I would like to take it off so it can be replated. How can it removed?
    Problem Solver:
  • 19 Answers
All you have to do is unscrew it counter clock wise
Posted on Feb 03, 2009
Over reving
Can be a number of things (check all of these):
  1. Stuck throttle linkage or accelerator pedal;
  2. Loose butterfly on throttle body;
  3. Stuck or malfunctioning idle air controller;
  4. Loose or damaged throttle body or bad throttle body gasket;
  5. Cracked intake manifold or bad intake manifold gasket;
  6. Bad ignition control module.
Jun 24, 2014 | 1994 Eagle Summit
Where do you find the model number on an Eljer toilet tank?
If there is a model number you will have to remove the top tank and look on the bottom of it.
good luck
Apr 18, 2014 | Eljer 141-0220-00 Toilet Tank White
It is not charging
Symptom 1 bad brick charger, check it with another iPhone. Symptom 2 bad sync cable check your charger with another sync cable Symptom 3 tarnished dock connector brush connector with a CLEAN used toothbrush, until all tarnish is removed, then check with a known good charger and sync cable. Good luck!
Sep 14, 2013 | Apple Black Iphone Model A1241 8gb
Need reviews on Eljer Whirlpool Triangle Tubs. Eljer a Good Tub to Buy?
Eljer is owned by Jacuzzi Whirlpool. Very nice tub. Eljer is one of the bigger Bathtub Mfg out there.
Not sure why he has not heard of them. Lowes is probably the biggest seller of that brand.
Rod
US Parts Center
Feb 07, 2013 | Eljer Triangle WP 60x60 LH 10JT
Water heat will not stay lite. will light but goes out when you turn the knob from pilot to on
Water heater brand, model number, type, location and approximate age are not known.
It is possible that water heater has tripped the FVIR system.
Water heaters manufactured last several years will shut down if exposed to flammable vapors, or high heat inside combustion chamber caused by inadequate air supply or clogged air intake, or bad venting.
Solutions range from replacing water heater, to cleaning air intake, to replacing-resetting TCO, replacing TRD glass vial, replacing gas control valve, installing louvers so more air gets to water heater, removing water heater from dusty environment, etc.
Other cause can be bad gas control valve, and possibly bad TCO, or tripped ECO requiring reset or replacement of gas control depending on specific brand and model number.
Review you product manual, look for identifying information on label on side of water heater.
Copy following links for basic troubleshooting:
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Jul 13, 2012 | Water Heaters
No air is blowing in my 2004 Nissan Maxima. I put 12 Volts directly to the blower and it starts blowing. I checked if current was coming from the feed wire and it was. But when I plug it back in, it...
The engine oxygen sensor code is a different maintenance item and has nothing to do with the cabin blower.
If you have a clogged vent, dirt-loaded heater core or stuck air door, the blower may be running while installed, but no air is moving. You did not say whether the blower was left installed or removed for your test with an independent power source.
If you have voltage on the connector to the blower, but it doesn't run when it's connected, then you have a bad connection in the connector or an open ground. Check for tarnish or dirt buildup on the connector terminals. My favorite means of removing light tarnish is a pencil eraser, but for the heavy tarnish I usually see on automotive electrical equipment I use Scotch-Brite abrasive sheet (not the kind on a dish-cleaning sponge, the kind used for metal polishing). If the male terminal is a flat blade, you can clean the female terminal by wrapping a strip of Scotch-Brite around the end of an ignition file or similar stiff strip of metal and running that into the terminal. If it appears the female terminal blades are spread too much to make reliable contact with the other terminal, try pushing them together with a jeweler's screwdriver.
It's also possible there's a sensor circuit (temperature, airflow or closed-loop motor speed control) that controls the blower that isn't working properly. What happens when you try to run it at full speed and maximum heat or cool?
Oct 30, 2011 | 2004 Nissan Maxima
I have a 1998 Ford taurus. It starts fine but then dies and also when slowing down the RPM dropped and it stalls. Can start again, but it dies off pretty qickly.
need to check the idle/air control valve.the valve gets sludged with oily tarnish and moves slowly and can'y keep the car idling properly. may also want to clean the throttle plate , it too can be sludged with the same tarnish limiting the air flow.
Jul 30, 2011 | 1998 Ford Taurus
Need an exploded drawing for an Eljer Corner Toilet Model 091-4510.
Here are pdf files that may help. Its all I have found thus far. Please give a 4 THUMBS UP if the free answer was of any help. Good Luck and have a grt day.
www.eljer.com/assets/documents/eljer/spec/SpecSheet_2497.pdf
www.eljer.com/assets/documents/eljer/install/Install_2497.pdf
Apr 01, 2010 | Home
Motor turns over but will not start
first thing is to check for fuel preasure,on top rear on engine theres a shrader valve for testing the fuelpreasure you just need a gauge. 9-13 psi is what it should be,next is to check for spark at the plugs, if theres no spark then have the control module tested.
Dec 28, 2009 | 1989 Chevrolet S-10 Blazer
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
