Question about Kenmore 24032\24036 Top Load Washer
I have a kenmore 70 heavy duty washing machine, and a whirlpool Imperial Gas dryer. The hot water hose busted and has caused the dryer to continually have the buzzer sound off. How do I stop it from continually going off and/or how do I restart the pilot light ti the dryer or is it electronically started?
  • Mark Egan May 11, 2010
    The pilot is 99.99% of the time electronic.
    As for the buzzer, I'll have to think on that for a bit. How long has it been since the water hose broke, until now?
    Has the dryer had a chance to dry out?
    And give me the complete model number of the dryer so I can try to find a wiring diagram.
  • 15,935 Answers
48 hours minimally.
It is pilot-less ignition.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Fills with waters starts making a buzzing sound
Check to see if there is something(sock) in the pump. If not, try spin washer with pump hanging down, but not with hoses off.
Jan 12, 2010 | Whirlpool Washing Machines
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
No cold water on any cycle. hot water fine.
The cold side of the water inlet solenoid is not working.
May 29, 2009 | Kenmore Washing Machines
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore heavy duty series model 82672810 hearing a
i would guess you have something stuck in the pump.
you will need to remove the cabinet and then find the hoses going into the pump. when you remove the hoses, you will find something inside the pump causing the noise.
Feb 23, 2009 | Washing Machines
Whirlpool imperial dryer/kenmore 70 series heavy duty washer
This is a pilot-less ignition. You should wait at LEAST 48 hours for the water to evaporate as much as possible.
Longer if possible.
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
The screens are filled with minerals which cause the washer to fill very slowly, need to know how to get at the screens so I can clean them. Kenmore Heavy Duty 70 Series washer.
HI thanks for your question.remove the hot& cold hoses. inside the valve you will see screens. scrape with a small screwdriver. replace hoses & try. if it works, great if not replace water valve. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Washing Machines
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
51 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
